Identifying a CX/VX Transmission - Fuelly Forums
Old 08-07-2006, 03:48 AM   #1
Are there some identiying marks on a CX/VX transmission that distinguish it from the other models? If not, how can one determine a CX/VX tranny by looking at it?
Thanks!
-- Scott
GasSavers_scostanz is offline   Reply With Quote
Old 08-07-2006, 04:01 AM   #2
lindermant's Avatar
see the notes section on the link below:
http://www.knology.net/~jediklc/gearratiosdseries.htm
hope this helps!
lindermant is offline   Reply With Quote
Old 08-07-2006, 08:40 AM   #3
The one in my basement certainly is. It's for sale, of course.
Old 08-08-2006, 06:08 PM   #4
Send a message via AIM to molecule
i've got 2 cx/vx trannies as well 4 sale
j*f encoded on the sticker by the front torque mount
where * = letter/number
my memory mastery reminder for this is "Jah Fuel"
i'm not sure on how complete this is for identification of them on a regular basis...
of all the cx/vx trannies i've seen...3 or 4...they all had it...
BE ZEITGEISTED
molecule is offline   Reply With Quote
Old 08-28-2006, 11:40 PM   #5
NO NO NO NO NO.
your best bet is to get an old clutch. mark it. Place the mark at 12 o' clock
push the shift rod into the trans, putting it in 4th gear (0.853)
mark the differential.
the final drive is 3.25, 4th gear is 0.853
3.25 * 0.853 = 2.77225
it should take 2.77225 full revolutions of the clutch to make one full revolution of the differential.
so it should turn 2.77 times and end up pointing a little after 9'o clock to make one full revolution.
and of course make sure that the sstamp near the oil fill plug says a000 instead of b000.
serial numbers mean nothing.
GasSavers_bense is offline   Reply With Quote
Old 08-31-2006, 04:13 PM   #6
Thanks for the advice everyone. I picked up a CX tranny a couple of weeks ago for $75 and it goes in the car tomorrow hopefully. The sticker says J8B and I did the suggested test and I ended up a little after 9 o'clock so I'm pretty sure it was not misrepresented by the seller.
-- Scott
Old 08-31-2006, 04:16 PM   #7
I have one for sale as well, *cry*
Old 09-24-2006, 11:23 AM   #8
kwtorbe's Avatar
Is it possible to put an HF transmission in my '97 civic HX without to many modifications---I see the HF is cable while the later HX has hydro control.
kwtorbe is offline   Reply With Quote
Old 09-24-2006, 11:33 AM   #9
Matt Timion's Avatar
Completely different mounts, pedals, etc.
is there a reason you want the HF transmission over the HX/CX/VX transmission? I'm pretty certain that the existing transmission will actually be longer geared than the HF transmission.
Old 09-24-2006, 12:15 PM   #10
Matt, the HF has longer gearing than the vx/cx, which has longer gearing than the HX.
Anyway, yeah, you won't have much luck with it, I'd toss a cx transmission in if I were you (or vx, whatevs).
Here's the relevant gearing too look at: http://crxmpg.com/9200dgearing.html
How to compare exact car models? totalwise Fuelly Web Support and Community News 5 06-05-2012 04:19 PM
Import broken? Woody14619 Fuelly Web Support and Community News 1 02-26-2010 07:13 AM
Suggestion: Advanced car search otavio General Fuel Topics 1 03-16-2009 01:43 PM
Distinction in 'garage' for cars we no longer own Smitty Fuelly Web Support and Community News 3 09-12-2008 07:50 AM
New Camry Hybrid... cool display! Matt Timion Hybrid Vehicles 6 01-19-2006 05:29 PM
