How to get to ECU in Civic VX? - Fuelly Forums
Old 04-26-2013, 06:57 AM   #1
sebass's Avatar
Guys i'm trying to get into ECU but it's all covered with carpet and don't want to rip the carpet apart. What are the steps to get to the ECU without ripping up the carpet.
sebass is offline   Reply With Quote
Old 04-26-2013, 05:32 PM   #2
Pull up the plastic when you open the door. Pull carpet away and there are 4 10mm bolts holding it down. Why are you messing with it?
Rusty94cx is offline   Reply With Quote
Old 04-26-2013, 07:00 PM   #3
sebass's Avatar
Thanks Rusty. I just tried. I pulled it out 3/4 out. I thought there was more to it. I'm going to be running wires from ECU (VSS, Injector, ground and positive) for MPGuino ))
Also have to fix A/C cluster lights as bulbs are out so that's next.
Old 04-28-2013, 07:08 PM   #4
A/c cluster is a bear. Whole dash or pull stereo out and wrestle 3 Phillips screws out and back in. Have fun don't break the knobs when pulling them off. I keep those spares in stock. Also make sure to use the blue rubbers on the bulbs. If not it's a little to bright.
Old 04-29-2013, 10:31 PM   #5
sebass's Avatar
Rusty thanks man. I have to get this done in sprint as summer i too hot, fall is too windy and in winter i can't see sh1t without those bulbs to change heating. Needs to be done. I have pictured diagram from honda tech forum. This will be whole day thing from what i've seen from mpguino. It took me whole day and it was suppose to be 2-3 hr project but that's due to some incorrect info.
Old 04-30-2013, 05:41 PM   #6
Sorry to hear that. It's really only an hour at most but a bear. I changed mine in my cx when I had the whole dash out. that's how I know about the blue covers. I didn't have any spares and didn't think it would be a problem. Make sure you use them.
$100 Civic VX 5 wire O2 / LAF sensor. will it work? GasSavers_ian General Maintenance and Repair 3 12-22-2012 08:24 PM
LLR Tires for a 93 Ford Escort GT jj94auto General Fuel Topics 12 05-24-2012 05:43 PM
HELP! Best tire for CRX HF (165/70 vs 155/80 vs 175/70 for economy &/or performance) goobous General Fuel Topics 6 05-23-2012 06:00 AM
