How slow can I go in any given gear??? - Fuelly Forums
Old 08-21-2006, 03:09 AM   #1
Compaq888's Avatar
How slow can I go in any given gear. I can't figure it out. Can I go 25mph in 5th? How can I tell If I'm going too slow in any given gear and is hurting the tranny or engine????
So far I've been shifting at 1400-1500rpm into the next gear.
I shift into 5th at 30mph is that okay??? It's at 1400-1500rpm.
3.250 1st
1.782 2nd
1.172 3rd
0.909 4th
0.702 5th
Final Drive
3.722
Tire size is 185/65/14
Old 08-21-2006, 07:20 AM   #2
Matt Timion's Avatar
Generally speaking, as long as the engine still goes (ie, you still have power) you're okay.
I've done 5th gear at 35 mph many times.
Old 08-21-2006, 09:03 AM   #3
GasSavers_brick's Avatar
I drive in the highest gear that will let me keep the car moving. If I'm just cruising, I can use 5th as low as 30mph. I like to down-shift before the car gets to 100% load (WOT) because I don't want it going open loop and running slightly rich if I can avoid it. So if your foot is on the floor, you have chosen a gear that is too high. But I don't think it's possible to do damage to the engine or drivetrain from having the RPMs too low.
The only caveat is that you may burn more fuel by accelerating in way too high of a gear with the engine turning too slowly vs. one gear lower and allowing the engine to run where it makes power more efficiently. That's mainly because you could end up trying to accelerate forever rather than getting the job done and backing off to a steady cruise.
Also keep in mind that driving in a very high gear makes fuel economy EXTREMELY sensitive to throttle position. It's going to be difficult without any kind of instrumentation, but you need to take care to make sure that your foot really is using the lightest touch possible to maintain a given speed. This could mean the difference between 25mpg and 50mpg at any given moment with little or no seat of the pants indication.
'07 Toyota Prius
Old 08-21-2006, 09:24 AM   #4
I'll second everything brick said. I'd prolly be in 5th at 25 in your car,
Old 08-21-2006, 11:16 AM   #5
philmcneal's Avatar
brick you said it all! just remember to listen to your engine... and you can tell its lugging if it doesn't purrs but it sounds rough and you feel more vibriation than ever... but ya light feather throttle its almost impossible to lug unless you start pressing the throttle some more... if you need the juice just quickly downshift one gear since the difference is very little at that rpm. Then shift back once the road steadies.
Old 08-21-2006, 02:24 PM   #6
FE nut
diamondlarry's Avatar
I quite often cruise at 25 in 5th. I can even accelerate to some degree as long as I'm not in a hurry. The lowest I have ever cruised in 5th is 20; no acceleration though. My engine is one that has a bore that is smaller than the stroke which makes for very good torque.
2007 Prius,
Team Slow Burn
Old 08-22-2006, 12:43 AM   #7
no gas pedal in 5th at 16-20 mph gets me 70-80 mpg 800rpm but the lowest speed I can give it any gas is about 20mph some where around 1000rpm. Too slow an rpm and the oil spray on the underside of the pistons will not be enough to cool the pistons and you start cooking things. MPG indicator getting too low is an indicator of too low an rpm for the load also the power pulses at low rpm can damage the gears in the tranny because the springs in the clutch are bottoming out and that occurs when you get chattering which is bad!! Heavy loads also exposes the exhost valve to longer pulses of hot gasses before they close and cool off. Timing also gets really retarded with the lightest of throttle opening at low rpm.
Add Gal / 100 mi (in both US and UK) as a display unit option darkluke4 Fuelly Web Support and Community News 2 04-04-2012 06:05 AM
Total Spend for last year udtrev Fuelly Web Support and Community News 4 01-12-2010 06:10 PM
Suggestion: Other ideas for comparing cars' data jjmatt33 Fuelly Web Support and Community News 6 08-08-2008 02:38 PM
1988 Honda Acty Attack all wheel drive iburnh2o For Sale 12 06-01-2008 05:30 PM
vegpowered systems GasSavers_Diemaster Vegetable Oil and BioDiesel 2 09-08-2005 05:53 PM
