How do I remove the XFI valve cover? - Fuelly Forums
Old 09-06-2006, 10:53 PM   #1
Matt Timion's Avatar
I was at the junkyard today attempting to remove the valve cover of the Metro XFi. I wanted to get the camshaft out.
I removed every bolt I could see, and then I also removed the distributor and every bolt around it. That thing wouldn't budge.
Is there a secret bolt somewhere, or do I need to know a magic password to get that thing off?
Old 09-07-2006, 07:28 AM   #2
Send a message via AIM to Brian D.
You just have to be very patient. After seeing several of these cracked in the junkyard I realized this. I haven't yet taken mine off (to replace the leaking valve cover gasket), but I practiced on one at a junkyard first...then bought it when I successfully removed it, just in case I crack my own. You just have to baby it. Get something thin (blade) and run it along the opening/crease. Then get a flathead screwdriver and work every angle you possibly can on between the head and valve cover...using ANY possible leverage point you can find. This should (hopefully) only take about ten minutes of working it. Eventually you'll get one corner to pop up just a bit. Then you can stick your screwdriver head in there and carefully use IT for leverage when you pry up the other side. Of course, you'll have to be very careful not to ding/score any part of the head with your screwdriver. Good luck & have fun!
GAS GSLR
Brian D. is offline   Reply With Quote
Old 09-07-2006, 08:49 AM   #3
Hmm... since you're just after the cam, will the yard charge you for a dinged head/broken valve cover?
I just checked my manual: it just says, remove the nuts, then the cover. No secret handshake required.
Want me to ask specifically about the XFi cover on teamswift?
Old 09-07-2006, 09:01 AM   #4
If you want to ask, that would be great. I only had a leatherman and a few different sockets with me yesterday, so I was unable to really work hard on it. If I have the time today I'll go back with a prybar.
As for the damaged valve cover, they could care less. I only get charged for what I buy.
Old 09-07-2006, 09:07 AM   #5
Maybe they should rename the place "Break a Part".
Old 09-07-2006, 09:09 AM   #6
I can bring my mini-sludge hammer with me
Old 09-07-2006, 09:11 AM   #7
Looks like this isn't an uncommon problem:
See here: http://www.teamswift.net/viewtopic.php?p=81149 , go down to Wed Nov 24, 2004
Looks like you need to work the seals off the valve cover studs to get the cover off.
Or just bring the mini sledge.
(If you do happen to get back there to do this, and it works, can you keep the cam timing belt gear too? I'm not sure if it's identical to the stock one.)
Old 09-07-2006, 09:23 AM   #8
Cheap therapy!
First fill up on brand new car? kwakaman Fuelly Web Support and Community News 1 02-10-2012 06:49 AM
Average running mileage on dashboard mistakely same as last fill-up. MatrixDom Fuelly Web Support and Community News 3 06-15-2011 03:21 AM
issue with image in signature banner brian83 Fuelly Web Support and Community News 5 09-13-2010 04:33 AM
Demand and FE SVOboy General Discussion (Off-Topic) 1 07-22-2006 02:22 PM
The medical system is bulls**t Compaq888 General Discussion (Off-Topic) 4 06-19-2006 10:06 AM
