Here's the water hose routing:
And one of the evap canister:
EDIT: found a better picture of the vac hose routing to the top of the Evap Canister
Kind of hard to tell but there is a drain on the bottom, one larger vac hose on top goes to the breather tube to the tank, then the small vac hose to the purge solenoid located on the rear of the intake manifold near the brake booster, the other larger vac hose (usually covered by a woven material) goes to the large port on the top of the throttle body.
