Honda guys - need help filling transmission fluid - Fuelly Forums
Old 06-28-2006, 09:33 PM   #1
Matt Timion's Avatar
The VSS won't budge, and neither will the fill bolt.
I've read that some people fill it through the reverse light switch. Is this advisable? Are there any pros or cons to doing it this way?
Old 06-29-2006, 02:05 AM   #2
krousdb's Avatar
Can you get a torch on that fill bolt? That is what I used to remove the plug to install the EBH.
Old 06-29-2006, 04:53 AM   #3
Moderator
GasSavers_DaX's Avatar
The fill bolt is always tight. I jack the car up and get at it from underneath. Put your closed end 17mm on there and whack the wrench with a 3 lb sledge. Works every time. I posted in the other thread for what I'd do to get out the VSS.
Old 06-29-2006, 10:19 AM   #4
Matt: They make a torch for Propane/Mapp which is for high temperature's. The one I have is on about a 3 foot hose. When you light it, it has a whirling sound to it, like a idling jet, sort of. If you have or can get one of those, they get hot enough to braze very thin metal with, but they can get the bolt hot enough to allow you to get it out. If you don't have one, they can be a very worthwhile tool.
Old 06-29-2006, 10:29 AM   #5
LincolnW's Avatar
I would definately do like the others suggested and focus on getting that filler bolt off. You need that anyways to know how much fluid to add so you don't over fill it.
LincolnW is offline   Reply With Quote
Old 06-29-2006, 10:33 AM   #6
You know what? After looking at my DX transmission I have decided that Jiffy Lube screwed me over.
Last October they did a "service" on the transmission, which supposedly included putting new fluid in there.
You would assume that the caked on black oil would be somewhat disturbed around the transmission fill bolt if they actually did do this.
Surprisingly, it is not disturbed, but I am.
Adding the 2013 Ford Fusion Energi? JDsEnergi Fuelly Web Support and Community News 1 06-27-2013 01:49 PM
Top 3 images by year jandree22 Fuelly Web Support and Community News 0 02-01-2013 06:36 AM
Why fill my tank? acidtonic Fuelly Web Support and Community News 11 12-27-2010 07:27 AM
What do you put in your car for a little extra vroom?!? everythingzen General Fuel Topics 12 09-30-2008 04:17 AM
Support for motorbikes wrighth1 Fuelly Web Support and Community News 9 08-18-2008 07:11 AM
