high pitch squeak when engine bogs? - Fuelly Forums
Old 07-10-2006, 11:25 AM   #1
With an hf tranny now installed in my d15b1 civic (thanks to Ben), I have been hearing a new sound. First of all, the engine bogs and threatens to buck before the car warms up just after upshifts. It only happens after upshifts, as if I am upshifting into too high a gear. It now happens sometimes after the car warms up, and it is in all gears 2-5 for a short duration after upshifts. With the clutch depressed, the sound goes away, and although that might in some cases hint at the input bearing, I think in this case it is just the mismatched low torque engine/tall geared tranny, any thoughts? The sound is a high pitch squeak that pulses and sounds as if it is a circular motion that is causing it, which again may hint at the input bearing, no? Please Help!
EDIT: Ben, we didn't change ignition timing, cuz we couldn't budge the distributer, right?
budomove is offline   Reply With Quote
Old 07-10-2006, 02:38 PM   #2
Budmove: I am just speculating, but I wonder if you adjusted the clutch cable just a little two tight, so that when you release the pedal the clutch tines still are just touching the throwout bearing. I don't think it's the throwout bearing, because if it was the problem, it should get noisy, when you put the clutch in, not the other way around. How much freepedal do you have with the clutch. It should be like an inch or so, at a minimum, as I recall.
When you get things setteled, please post something on your mileage, pre and post. I have a 89 and it sounds to me like I have to find an HF gear box to put in.
Old 07-10-2006, 07:03 PM   #3
can you explain please, freepedal?
Old 07-10-2006, 07:07 PM   #4
I imagine that's how far you kick it in before the clutch does its business. Try losing the cable a bit.
Old 07-10-2006, 07:43 PM   #5
Thanks guys, that did it! So happy It wasn't the input shaft bearing or something bad. You guys are lifesavers, I may have actually brought it to my mechanic for a diagnosis.
m.fuelly.com crashing Mobile Safari on fuel-up reefdog Fuelly Web Support and Community News 10 08-20-2008 07:55 AM
