Originally Posted by BEEF
one thing you could do is change out the readily accessible hoses first and see what happens. I would think that it isn't an actual gas line but the evap lines for the vapor.
That would certainly explain the code, but it wouldn't explain the starting.
I had that link in my post already.
Originally Posted by GasUser
I bought it new and at around 150,000 miles the original fuel pump started acting up and I would turn the key to the "on" position for a couple of seconds and could hear the fuel pump power up and pressurize the system. Then it would immediately start. So then one day it just crapped out.
That describes my history pretty well, too. It was earlier than 150,000 miles when the pump died.
I took it up the street to a real mechanic (I am not a real mechanic) and he replaced the fuel injector harness and injectors. It looked like an octapus (with plastic fuel lines and fuel injectors at the ends).
There is a valve on the fuel rail and with the proper tool you can measure the fuel pressure. It should be holding 40-60 pounds pressure (if I remember right) or something is not right.
This is definitely something I need to check, since it's probably where my starting problem is.
So if you were to run it on 1/4 tank or less all the time, it could make the pump run hotter than it needs to and shorten it's life.
I believe that was the cause of my first fuel pump's untimely death. Now I try to fill it at 50% every time.
It is possible these 2 problems are a coincidence.
Possible, yes...but really strange that they ALWAYS accompany eachother. They've come and gone on their own, repeatedly, and always came/went together.
Sometimes a FSM is so handy with the diagnostic sections, but they are so pricey. I got the regular paper copy FSM on my jeep and my but is still sore. Maybe some where on line you could get a cd copy for yours.
Flying Spaghetti Monster?
Okay, I know, a Factory Service Manual. You're right, they are definitely pricey. I've looked for them before.
