Honda guys... please help.
I have three pictures that I need help identifying.
First question is for my dpfi to mpfi swap. The following picture is of the new engine (MPFI, OBD1) looking at the injectors from BEHIND the engine.
On my DPFI I have two sets of injectors. Injector 1 has a yellow wire and a yellow/black wire (ground I assume). Injector 2 has a red wire and a yellow/black.
In the picture above, what are the injector numbers? I need to know this so I can properly connect the existing injector wires to the new ones. ALSO... for the ground on the new injectors I'm wiring up (3 and 4 I assume) can I just splice into the grounds from injectors 1 and 2?
Okay, on to the next question.
These next two pictures are from the d15b2 engine, DPFI. I have no idea what these wires are as I cannot find an equivilant on the new engine. both of them are taken from behind the engine.
Any help would be appreciated.
