HELP Honda Civic LEAN burn issue - Page 3 - Fuelly Forums
Old 12-12-2011, 06:21 PM   #21
Re: HELP Honda Civic LEAN burn issue
Originally Posted by honerscivic View Post
Maybe the best way would be to tap into the o2 wires to see how lean its getting before misfiring? I have an extra sensor that came with a spare motor that I tried and had the same issue, power mode is fine, lean burn feels like a misfire ( no ping/detonation sound) so much that I couldn't stand it. I put the percieved good one back in and runs fine. Sounds like you need some hard data at this point.
Sounds like you had the same problem. Was it the O2 or a wiring problem?
Kendaddy126 is offline   Reply With Quote
Old 12-13-2011, 11:37 AM   #22
It was the sensor. I bought the car with a new one already installed and given that I can feel the power going down and can get ~50 MPG, I assume Im getting lean burn. I put the used sensor in and those symptoms came with it. Since your sensor is new, I think the only way to know is to tap into the wires at the ecu.
Here is a link
http://ecomodder.com/forum/showthrea...s-info-23.html
honerscivic is offline   Reply With Quote
97 hx hi milage msweatherhead Introduce Yourself - New member Welcome 1 06-08-2011 11:27 PM
MPG loss due to supercharger bobc455 General Fuel Topics 18 09-20-2010 12:23 AM
Wideband Ntk O2 Sensor daygobaker For Sale 0 11-28-2009 02:20 PM
From Auto-X to Fuel Friendly, a ZX2 PHeller Introduce Yourself - New member Welcome 3 05-06-2008 10:34 AM
