Got my math right? - Fuelly Forums
Old 03-01-2010, 08:40 AM   #1
Got my math right?
Just trying to see if I have my math right... I just bought a set of Honda VX wheels and was going to buy tires for them. Since the 165/70-13's seem to be fairly limited, I was thinking about going with the Kumho Solus KR21's in a 155/80-13, but the plus seems to be the 155/80-13's are about a close to stock size as I could get anyway.
So for the math...
STOCK SIZE (1995 Civic DX sedan)
175/70-13 would leave a 175*.70=122.5mm sidewall. Wheel diameter is 13in or 330.2mm. Total tire diameter would be 122.5*2+330.2=575.2mm.
NEW TIRE SIZE (on VX wheels)
155/80-13 would leave a 155*.80=124.0mm sidewall. Total tire diameter would be 124.0*2+330.2=578.2mm.
That is a difference of 578.2/575.2-1=0.52%
So at a speedometer reading of 70mph my car will actually be going 70*1.0052=70.37mph.
Does that all look correct? Just trying to make sure I actually know how fast I am going and how far off my MPG calculations might be.
ben98gs is offline   Reply With Quote
Old 03-01-2010, 03:22 PM   #2
http://www.miata.net/garage/tirecalcold.html
Old 03-02-2010, 07:03 AM   #3
So yes....
Old 03-02-2010, 02:07 PM   #4
Depending on how accurate you want your speedometer, if you went up a couple sizes to something like a 185/80/13 you would probably be able to get a litte better mileage because of the taller gearing, but you'd need to verify the larger tires were not going to create any rubbing issues.
Hipermiler
#47 on my way to #1
Old 03-02-2010, 04:08 PM   #5
Well then speedo and odometer would be off and I would have to do more calculations on my fuel economy to get "actual fuel economy"... lol I am too lazy for all that. Will probably just go with the 155/80-13, especially since tires are almost half as much.
Help Me Explain this WorkingOnWise General Fuel Topics 9 06-09-2008 08:38 PM
SPIN drying cloths DracoFelis General Discussion (Off-Topic) 12 12-16-2007 06:41 PM
Threw caution to the wind MnFocus Aerodynamics 13 06-28-2007 06:09 PM
Toyota Tundra Lover cowboyjack999 Introduce Yourself - New member Welcome 9 02-15-2007 10:13 AM
WTB Honda HX rims GasSavers_Jack Wanted to Buy 6 06-20-2006 06:09 AM
