Goo Remover - Fuelly Forums
Old 04-30-2009, 10:34 AM   #1
Goo Remover
Anyone know a product that will remove the goo that remains after the stick-on molding strip is removed. The big chunks come off faily easy, but a thin film of stickiness remains. i've tried wd-40, alcohol and 409 with little success.
LarryJ is offline   Reply With Quote
Old 04-30-2009, 10:37 AM   #2
I have some stuff made specifically for removing goo from cars, that I've been intending to use but I just haven't bothered. I think it's this stuff:
http://www.3m.com/Product/informatio...e-Cleaner.html
This stuff would probably do it too:
http://www.amazon.com/Un-Du-4-Ounce-.../dp/B00009WBZ7
Old 04-30-2009, 10:49 AM   #3
Goo Gone Extreme. Mine came in a metal can, I love that stuff and it's one of the only things you can use that won't scuff up your paint.
DO NOT use alcohol or anything like that unless you plan on repainting the car or you just don't care.
- Kyle
Old 04-30-2009, 07:15 PM   #4
|V3|2D
thisisntjared's Avatar
i love googone
Old 05-01-2009, 05:26 PM   #5
wd-40 or pb blaster works on some goo
Old 05-01-2009, 05:34 PM   #6
GasSavers_Erik's Avatar
Ammonia works pretty well on removing old, sticky window tint adhesive. But I'm not sure what it might do to the rubber molding...
Old 05-01-2009, 06:15 PM   #7
The 3M product is made by the people who make the sticky stuff and it does work.
So does Eucalyptus oil but I have no idea where you can find it in the US.
Local ******** / drug store perhaps?
Pete.
GasSavers_Pete is offline   Reply With Quote
Old 05-03-2009, 06:26 AM   #8
I have used "Goo Gone" with great sucess.
Dave
GasSavers_GasUser is offline   Reply With Quote
Old 05-03-2009, 06:34 AM   #9
I was wrong. This is the stuff I have:
3M Adhesive and Wax Remover
http://3m.hillas.com/pc-13852-1244-3...ver-12-oz.aspx
Adhesive and Wax Remover quickly removes wax, grease, oil and adhesive residue. It will not harm most cured automotive paints and is also suitable for vinyl and glass surfaces.
I tried to use it yesterday. It didn't entirely do the job. I may have to get some Goo Gone. I've got adhesive from door edge protectors that's stuck on my door edges and some that spread itself on the side of the car. Those door edge protectors don't stay on the VW like they do on my truck.
It also had no effect on some hot melt glue that was stuck from my early grille blocking attempts.
I'm thinking a hair dryer and a plastic putty knife might work, or maybe a drill-mounted buffer, if I can't find any Goo Gone.
Old 05-03-2009, 11:00 AM   #10
Goo Gone didn't work for me either on removing the molding adhesive. i just used the side of my thumb and my fingernail. That got most of it. the rest will be removed with a sander when the car is painted.
Reasonability checks on input Cookie Fuelly Web Support and Community News 11 07-07-2009 09:38 AM
Mazda5 in Eugene, OR Snax For Sale 3 08-16-2008 02:53 PM
