Geo Metro Owners HELP! - Fuelly Forums
Old 01-12-2007, 06:36 PM   #1
Moderator
GasSavers_DaX's Avatar
Ok, I'm going to look at a lady's Geo Metro on Sunday - not to buy, but to fix for her. I think she has a bad water pump bearing. She does NOT know what the trim level is, but she says she thinks it's a 1.0L (though she sounded unsure).
Before I back myself into a corner and agree to work on it I need to know a few things.
1) Does the car use a timing belt or a chain?
2) Is the car's hardware metric or standard?
3) Does removing the crank pulley require some special puller/tool/method?
4) I'm assuming the waterpump location is similar to that of a Honda - driven by the timing belt and behind a plastic shield that is behind the crank pulley. Am I correct?
Old 01-12-2007, 07:37 PM   #2
1) belt
2) SI wtf!
3) dunno
4) Nope:
(clicky=zoomy) Shares the alternator belt.
Good luck. It's tight back there (but then so are most Hondas).
Old 01-12-2007, 07:41 PM   #3
Tuggin at the surly bonds
Silveredwings's Avatar
Originally Posted by MetroMPG View Post
1) belt
2) SI wtf!
3) dunno
4) Nope:
The puller I needed for the water pump in a VW VR6 was the "engine puller." that's how tight it was.
Old 01-13-2007, 07:10 AM   #4
Moderator
1) belt
2) SI wtf!
3) dunno
4) Nope:
Haha, I didn't know...it IS a Geo American POS after all.
I'll still look at it, but this is way out of my comfort zone.
Old 01-15-2007, 08:53 AM   #5
Moderator
Well, got to look at it yesterday, it's a 4 cyl.
The water pump is driven by the alternator belt, but the pump extends behind the timing cover, so to get the pump off I'm going to have to remove the crank shaft pulley. There is no obvious way for me to hold the crank pulley still on this engine. It is one large 17mm bolt in the middle, but nowhere to hold the pulley. I'm going to try getting the crank pulley bolt off today, and if I can't, I'm not going to do the water pump.
Throttle Position During Acceleration and its effect on FE SVOboy General Fuel Topics 105 06-09-2009 03:33 AM
I will be bike riding across Iowa kickflipjr People Powered 11 08-02-2006 04:22 PM
Some glue that won't melt when it gets hot? SVOboy General Maintenance and Repair 16 08-01-2006 08:15 AM
New forum guidelines, FAQ Matt Timion Fuelly Web Support and Community News 14 05-21-2006 07:26 AM
Hybrid Scooter kickflipjr Motorcycles 4 10-01-2005 02:31 PM
