Gas Tank Swap - Page 2 - Fuelly Forums
Old 11-08-2008, 08:01 AM   #11
Yes they are lighter. A gallon of gas only weighs a little more than 6 pounds. An extra fifty or sixty pounds isn't going to make any difference. Besides the cost of the small amount I will be spending on gas will be offset by me not buying the inevitable mountain dew. I am not going to put gasoline in the car. One mishap and the smell would never come out. I just seems a little dangerous. Tanks are strapped on so I should be alright as long as I use the straps from the accord I take it off of.
seeodywhy is offline   Reply With Quote
Old 11-08-2008, 08:04 AM   #12
I have a 11.9 gallons tank with my VX (coming from a DX probably) and I get like 625 miles and more (1000km).
So 13-14 should be more then enough...
Old 11-08-2008, 08:08 AM   #13
Will an accord fuel pump being of a different size and pressure output matter if the crx pump doesn't just slide right in. I like the idea of a 90-93 accords 17 gallon tank if it's a direct bolt in or the 16 gallon tank from the previous gen.
Old 11-10-2008, 05:17 AM   #14
I was mistaken, I thought your car already had a 12 gallon tank. Rockauto.com lists a 12gallon tank as the correct one for a 1991 Honda CRX HF, and says it cross-references with several civics. It is the same tank as the civic hatchback of the same year.
rockauto.com is kinda cool, for most parts you can look at a picture of the particular part, and they will tell you every other car that part fits on. I had been looking at both model numbers and the pictures of the tank shapes when comparing what would likely fit from other '91 Hondas.
Think inside the Box!
Improbcat is offline   Reply With Quote
Hydrogen or H2O Systems 1Jal1 General Fuel Topics 4 10-11-2008 02:20 AM
Why did it take me so long to find this place? Baranfin Introduce Yourself - New member Welcome 6 05-31-2008 05:17 PM
Does anyone put their GasSavers sigs on other car forums? (Also, the $15 gallon....) landspeed General Discussion (Off-Topic) 5 05-27-2008 01:10 AM
How many miles do you have on your car/truck? Tepco General Discussion (Off-Topic) 55 05-07-2008 04:05 PM
