Gallons per hour - Page 2 - Fuelly Forums
Old 04-24-2007, 02:43 PM   #11
silverinsight's Avatar
My Insight shows .2~.3gph at idle.
It shows the same with engine on coasting when the Honda FCD shows 0L/100km. I talked to Ron DeLong at Scangage about this his reply:
"The Honda reports that fuel is being used during fuel cutoff. We are working on a way to determine when fuel cutoff is active, but have not found out how to do this yet."
silverinsight is offline   Reply With Quote
Old 04-24-2007, 02:50 PM   #12
You would think that a high rpm and off throttle position would mean there is no fuel being injected - seems simple enough - just have to set the closed throttle position value i.e. the lowest number it drops to should do it and have fuel cutoff. Unless there is a big throttle bypass going on.
Old 04-24-2007, 03:13 PM   #13
omgwtfbyobbq's Avatar
The injectors will pulse fuel through periodically to keep the cat warm, that may be what's being read.
Old 04-24-2007, 07:35 PM   #14
ELF
ELF's Avatar
Originally Posted by rh77 View Post
Fully Warmed (Integra)
0.2 - 0.3 GPH - Neutral Idle (min. load)
0.4 GPH - Drive Idle
0.5 GPH - Drive, A/C, Idle or Neutral with cooling fan kick
0.6 - 0.7 GPH - Drive, full electrical load, A/C, Idle
Fully Warmed sable is exactly the same as the Integra.
Old 04-24-2007, 08:15 PM   #15
GasSavers_Red's Avatar
Wow, talk about fuel sippers.....
1.1-1.2 - Cold Idle
0.6 - Warm Idle
0.7-0.9 - Everything on @ Idle (2 55w Fogs, Lights, Wipers, Radio, CB, E-Fan, AC)
Old 04-24-2007, 08:54 PM   #16
trebuchet03's Avatar
'00 Jetta 2.sl0w
.2-.3 gph -- closer to .3 though
11/12
Old 04-24-2007, 09:42 PM   #17
Team OPEC Busters!
GasSavers_Brock's Avatar
Jetta TDI .1 fully warm, sometimes flicks to .0
A hint on the scangauge is to set it to liters, when I am in liters I am at .2l when warm.
I am now convinced this is why pulse & glide or engine off coasting doesn't help my mileage much, but I can see how it matters more with a gasser.
Old 04-24-2007, 10:53 PM   #18
I rally need to get a SuperMID and learn something about mechanics so I can install it.
Old 04-25-2007, 01:14 AM   #19
caprice's Avatar
So if I wired in an injector shut off, it wouldn't show on my scan guage? Bummer. That would screw up my displayed MPG on the SG.
David
85 Chevrolet. 30 MPG or bust!
caprice is offline   Reply With Quote
Old 04-25-2007, 01:44 AM   #20
caprice's Avatar
Question
What size motors are those? If i remember right sables have 3 liter motors.
Good Idea with switching to liters per hour, for more accuracy!
While engine off coasting in neatral, my ZX2 is getting 9999 MPG according to SG!
For me .4-.5 is Warm in Park. I didn't write it down, but its around another .1 for drive, .1 more for AC, and another .1 blower on high and highbeams andwipers and brakelights.
I was trying to get a ball park idea what idle fuel consumption should be. My car is idleing like it is running on 3 and a half cyllenders, but is runs fine above 900 RPM. It was running worse earlier (.5-.6) before I found out a camshaft was a tooth off.
The big problem is, unlike most cars, it is hard to find answers in the internet for a Daewoo. I am going to try cleaning the EGR, Idle Air Control, and around the throttle blody. Also It may be a fuel injector, or a coil. Will check compression too. I really want to find what the problem is!
David
google+ integration? xchrislee Fuelly Web Support and Community News 3 07-15-2011 02:55 AM
No love for motorcycles... CopaDriver Fuelly Web Support and Community News 6 08-19-2008 09:49 AM
When to Fill up at the station to get the best value. GasSavers_Explorer Experiments, Modifications and DIY 25 11-02-2006 05:07 PM
Are CRXs easy to break into? GasSavers_Lance General Maintenance and Repair 20 09-20-2006 10:56 PM
How did you first find Gassavers.org? kickflipjr General Discussion (Off-Topic) 17 05-24-2006 08:28 PM
