Fix my car, :( - Page 5 - Fuelly Forums
Old 08-12-2006, 01:25 PM   #41
Just set it up so you can unplug the fuel relay?
Old 08-12-2006, 01:25 PM   #42
It was the yel/blk that did it. The main relay wasn't clicking off, so I assumed dan was right and I was getting constant power to it somehow. Anyway, with the blk/yel resoldered and the yel/blk left hanging it works perfectly, as far as I know.
Old 08-12-2006, 01:28 PM   #43
Why won't the site display my picture...link:
http://images5.theimagehosting.com/DSC00428.97d.JPG
Old 08-12-2006, 01:38 PM   #44
Are you talking about at the connector to the fuel relay?
Old 08-12-2006, 01:56 PM   #45
No, the round shock tower plug that you didn't give the pinouts for, it's in the picture.
Old 08-12-2006, 02:07 PM   #46
krousdb's Avatar
Originally Posted by SVOboy
Snip snip discovered that the second wire I clipped, which was a yellow black, would turn the engine off. I'll take a picture of it here in a second, but anyway, it runs out to the harness section under the IM then I can't follow it because the IM is in the way. I'm going to wire back up the first one I cut and see if it'll work normally with just that one wire cut...wonder what it does,
Yay for snip, snip.
Old 08-12-2006, 02:10 PM   #47
krousdb's Avatar
CEL is gone? Im sure that wire is for something. Check your lights and accessories and stuff to see what doesn't work.
Old 08-12-2006, 02:34 PM   #48
The connections for the other side:
yel/wht-yel/wht
yel-yel
orn/wht2-orn/wht2
blu/yel-blu/yel
wht1-wht1
blk/yel-blk/yel
orn/orn
yel/blk2-yel/blk2
yel1-yel1
yel/blk1-yel/blk1
red1-red1
yel3-yel3
yel, no number, engine side goes to egr. ecu goes to c8
yel/blk1, engine goes to main injector. dash, goes to main relay
yel/blk2, engine goes to aux. injector, dash, goes to main relay. yel/blk1 & 2 are joined and go to the main relay.
yel1, engine goes to aux injector, ecu goes to A3
yel3, engine goess to lock up solenoid, which you should no longer need.
Hope this helps.
Old 08-12-2006, 03:06 PM   #49
CEL was gone earlier, Dan, I switched two white wires on the other plug and it went away.
Also, I'm assuming the yel/blk I cut had something to do with the injectors and I just mispinned it somewhere else. When I did the obd1/mpfi I just ran both injector power wires together and into the 4 new injectors. I prolly just mispinned one of those two into the main relay somewhere and then cut it and everything's back to normal, I guess, *shrug*
i hope that's all there is to it, thanks for the help everyone, to echo matt's comment is his own thread, I've gotten more solid tech help here than ever on honda-tech,
Old 08-12-2006, 03:09 PM   #50
krousdb's Avatar
OK so where's the pictures of the tuck? And get to B8 ifying that B2! Then it will be the pimpness fo sheezy.
Fuelly badge not updating for about 2 - 3 weeks Need Fuelly Web Support and Community News 18 07-01-2012 02:01 PM
Modifying exhaust to increase mileage? Matt Timion General Fuel Topics 15 01-07-2006 07:44 PM
