Fix my car, :( - Page 2 - Fuelly Forums
Old 08-12-2006, 10:31 AM   #11
9 is cyp, which is cylinder position sensor or something I think. Time to check that wire out. It's the only code, so that means the problem isn't as huge as once anticipated. Need to figure out the ignition stuff. I'm going to print out my own DIY right now and check my wiring,
Old 08-12-2006, 10:41 AM   #12
the ignition stuff looks fine, but there is the possibility I misplaced the three thick white wires in the fusebox that come off the ignition. can someone get me a picture of which goes where or perhaps just tell me? Searching h-t now...
i feel the end is near.
Old 08-12-2006, 10:59 AM   #13
The blue/white wire should be wired to go to one side of fuse 19. The white/red wire should go to one side of fuse 17. The yellow wire shsould go to one side of fuse 18. The black/yellow should go to one side of fuse 13,14 and 1.
Most likely you have the yellow wire and the black/yellow wires switched. The yellow is ig2 and the black/yellow is ig1, but the problems you've described sound like they just got switched.
Old 08-12-2006, 11:02 AM   #14
http://images5.theimagehosting.com/DSC00427.aad.JPG
That's the picture I just sent to matt. I know everything else on the fuse box is correct besides being unsure of those. It sounds like we have differently colored wires?
Old 08-12-2006, 11:07 AM   #15
well, those three are correct, unfortunately.
Old 08-12-2006, 11:08 AM   #16
i'll have to see about this yellow wire business. i don't think i touched it but i need to check.
Old 08-12-2006, 11:13 AM   #17
Bunkness!
Old 08-12-2006, 11:27 AM   #18
Yeah, that big *** yellow wire is completely untouched. i fixed the cyp code (nine) by switching two white wires on a round plug, bling bling.
anyway, still no luck getting the car to shut off.
what i think is odd is that the ignitor power wire doesn't get power when the car is in I, but it'll still let the car keep going even after i pull the key out!
Old 08-12-2006, 11:37 AM   #19
Hold up a minute. Your saying that even when you take the key out of the ignition it shut's off?
Old 08-12-2006, 11:38 AM   #20
what i'm saying is that even if i take the key out the engine still runs, which is what i think you meant but you misworded it.
Fuelly badge not updating for about 2 - 3 weeks Need Fuelly Web Support and Community News 18 07-01-2012 02:01 PM
Modifying exhaust to increase mileage? Matt Timion General Fuel Topics 15 01-07-2006 07:44 PM
