Faster in gear than in Neutral - Fuelly Forums
Old 09-18-2007, 11:22 AM   #1
1993CivicVX's Avatar
umm... my car coasts faster in gear than it does in Neutral. I get up to 45, 46mph shifting through the gears going down the hill near my house without touching the gas during shifts. I get up to 44mph in neutral. What is the meaning of this? Most cars go slower when in gear, not faster! Anyone else's VX do this?
three stripes the charm!
Old 09-18-2007, 11:36 AM   #2
omgwtfbyobbq's Avatar
Every time you're in gear and below the idle fuel cut the engine's essentially idling in gear so you can get a very small advantage from the power the engine makes at ~45mph in yer case.
Old 09-18-2007, 11:38 AM   #3
is it more efficient then to leave it in gear for coasting?
Old 09-18-2007, 11:42 AM   #4
I'm guessing that coasting in N is more efficient, but you'll likely need a SuperMid or similar to verify it.
Old 09-18-2007, 11:56 AM   #5
yeah, I figured as much. Thanks for clearing that up!
Old 09-18-2007, 12:16 PM   #6
GeekGuyAndy's Avatar
It all depends on the gearing. If you are in a high gear and coasting at a reletively low speed, there is much less resistance from engine braking then if you were at a high speed.
GeekGuyAndy is offline   Reply With Quote
Old 09-18-2007, 12:30 PM   #7
trebuchet03's Avatar
As long as I don't put a heavy load on my idle engine - I consume roughly the same fuel idling in gear (moving) than idling in neutral. According to the SG. I can get mid 40's idling in 5th
But I need to figure some stuff out as I can't get my car to go into open loop while accelerating (WOT) under heavy load...
11/12
Old 09-18-2007, 01:04 PM   #8
Funny story: If I put my mom's car in 5th at 25 and coast I'll slow down, but if I turn on the a/c I can hold 25mph without pedal pressure,
Suggestion: Other ideas for comparing cars' data jjmatt33 Fuelly Web Support and Community News 6 08-08-2008 02:38 PM
VX rear wheel hubs -anyone replaced theirs? jadziasman General Maintenance and Repair 13 06-15-2007 12:16 PM
tire warped because of too much psi kickflipjr General Fuel Topics 30 04-24-2007 01:09 PM
Switchable power steering idea dieselbenz Introduce Yourself - New member Welcome 11 03-08-2007 05:58 PM
vegpowered systems GasSavers_Diemaster Vegetable Oil and BioDiesel 2 09-08-2005 05:53 PM
