The OEM VX exhaust doesn't have a traditional flex section, much less before the Cat....I don't believe that you have a stock exhaust on your VX.
#11 in that picture is the stock VX downpipe coming from the Maniverter.
The stock system has spring loaded bolts and rounded graphite gasket on the downpipe from the exhaust manifold that attach it to the B-pipe and the rest of the system to tack up any rocking motion.
IIRC, the stock diameter of the OEM system is either 1.65" or 1.75"
