EFIE schematics - Fuelly Forums
Old 08-29-2008, 07:45 AM   #1
EFIE schematics
I'm wanting to build one of these over the 3 day weekend but I cant' find any schematics. Anybody got one?
Also, if you have them, I'm looking for schematics for an Air Fuel Ratio Meter and a Pulse Width Modulator.
Thanks!
- Kyle
Old 08-29-2008, 10:23 AM   #2
I know I've found all of these here before but I'm having trouble digging them up again. I usually save this stuff when I find it but I can't find any saved copies either.
I did find this AFR meter on google:
http://www.scirocco.org/tech/misc/afgauge/af.html
I found this DIY PWM on google:
http://www.rmcybernetics.com/project...generator2.htm
Here's some EFIE digging...
http://better-mileage.com/memberadx.html
http://www.youtube.com/watch?v=PEHJ9te7gvk
http://www.esnips.com/doc/718eacd2-0...nhancer-Manual (or download at http://www.esnips.com/nsdoc/718eacd2...action=forceDL )
I wish I could find the ones that have been posted here before...I remember some pretty decent ones a couple months ago.
Old 08-29-2008, 11:34 AM   #3
That is too awesome, the parts for the AFR meter can be had for free!
- Kyle
Old 08-29-2008, 11:58 AM   #4
GasSavers_BEEF's Avatar
I don't know your background but be careful with the PWM. make sure it can handle the current you plan to put through it.
Old 08-29-2008, 12:07 PM   #5
I plan on making the PWM drive a FET to run the load.
- Kyle
Old 08-29-2008, 12:31 PM   #6
Almost free for the AFM. I ordered 3 of the LED driver chips for $13.
- Kyle
Old 08-29-2008, 02:13 PM   #7
I'll have to look and see if I have any information on a PWM or not. I know I don't have anything on the A/F meter.
Hipermiler
#47 on my way to #1
Old 08-29-2008, 04:33 PM   #8
Thanks!
Check this out maybe you'll find something you like here.
http://www.discovercircuits.com/P/pwm.htm
Hipermiler
#47 on my way to #1
Old 08-29-2008, 09:15 PM   #9
dude, I work with fets all day every day. that doesn't mean anything. a fet or field effect transistor doesn't specify current carrying capacity. the ones I work with will only handle about 13 miliamps per cell. obviously there are several cells paralleled.
engineering gets it done
remember, heat sinks and silly grease (conductive silicon grease) and you can parallel them if you need to. you could also go so far as using a cooling fan but now you are reaching the realm of just buying one that is pre-made.
Old 09-02-2008, 09:20 AM   #10
I started ordering parts for the EFIE. I got the 5.0v Voltage Regulators in today.
I can't believe how tiny they are! Part number is LM38690DT-5.0 and they're free from nsc.com. What threw me off is they shipped to me Next Day Air. Totally wasn't expecting that.
BEEF, I don't plan on running toooo much off this PWM, I got it working this weekend. The transistor I went with only handles 5.0 amps constant(8.0 peak) so if I do in fact build an HHO cell to try in the car I'll need to build a daughter board that the PWM drives.
- Kyle
quick fix of a shallow dent 1993CivicVX Experiments, Modifications and DIY 2 08-19-2007 05:22 PM
Your gas tank may not be as full as you think theclencher Automotive News, Articles and Products 8 06-13-2007 04:09 PM
New member /2007 Prius billynjoanna Introduce Yourself - New member Welcome 10 06-09-2007 10:56 AM
