E-manage, any body got some info? - Page 3 - Fuelly Forums
Old 03-04-2006, 08:42 AM   #21
16:1 instead of 14.7:1
Old 03-04-2006, 08:48 AM   #22
Compaq888's Avatar
whoa, that's a little lean.
whoa, that's a little lean. I was thinking 15.5 at max.
How does this sound??? 15.5:1 up to 10% throttle, 14.7 up to 40% throttle, 13.5 up to 100% throttle???
Old 03-04-2006, 09:05 AM   #23
16:1 isn't really all that
16:1 isn't really all that lean. And 10% throttle might not even be cruising.
Old 03-04-2006, 09:11 AM   #24
Compaq888's Avatar
I'll talk to a tuner first
I'll talk to a tuner first and see what they say.
Old 03-05-2006, 12:29 AM   #25
Compaq888's Avatar
hit the 1/4 tank mark at
hit the 1/4 tank mark at 320miles. Which is a little high. Especially that i've been driving mostly street. I usually hit the 1/4 mark at 280-300miles and that is with mostly freeway.
I go faster now and drive the streets more and still my mpg is climbing. Things I changed during the mid of this tank... 1) new air filter, 2) New air hose, 3) front tires at 44 psi and rears at 41psi.
This tank should be high 27/low 28's. I think it's possibe to break 30mpg mixed without tuning. But to get to my 35mpg mixed goal I need tuning. I still have to run auto-rx, finish belly and put it back on, and do pcv catch can.
Old 03-07-2006, 11:33 AM   #26
Compaq888's Avatar
Talked to a couple of people
Talked to a couple of people who know their stuff. If I lean it out the ecu will just add more fuel to get back 14.7 a/f
The only place the engine management for fuel economy would be beneficial would be when the engine is in open loop when it's cold. So basically it's not worth it. If I had a standalone it would be a different story. But since there is still the ECU in the car it's hard to control it. The e-manage is tuned in 500rpm incraments but at least it will give better numbers in power than the safc2.
End of story.
Old 03-07-2006, 11:37 AM   #27
How does the e-manage work
How does the e-manage work that the ecu can still override it and run off stock fuel maps?
Old 03-07-2006, 01:17 PM   #28
Compaq888's Avatar
The ECU runs on closed loop.
The ECU runs on closed loop. When you go WOT the ECU goes to open loop where it will listen to the e-manage or the safc2.
Closed loop is a sober chick
Open loop is a drunk chick. If you ever have gotten a chick drunk she will do mostly anything when drunk enough.
Old 03-07-2006, 01:51 PM   #29
Bunger's Avatar
That is true, after some
That is true, after some time the ECU will make adjustments to the long term fuel table and "unlearn" your settings in closed loop. This is why chipping your ecu is far superior to a VAFC, SAFC, E-Manage, etc. Plus you can change your spark also, (I think e-manage might be able to do this now).
You could always reset your ECU every trip. =)
Anger is a gift!
- Zack de la Rocha
Old 03-07-2006, 01:57 PM   #30
Compaq888's Avatar
the problem is you can't
the problem is you can't chip a obd2 ecu. You can only reflash it. Nobody does reflashes to 2nd gen altima ecu. There are only reflashes to the 1st and 3rd gen ecu altima.
Kickstarter - Video Series on Better MPG andyrobo General Fuel Topics 3 03-29-2013 08:49 AM
Recent Activity Jerrya2k9 Fuelly Web Support and Community News 1 02-29-2012 12:07 AM
Suggestion 108Acres Fuelly Web Support and Community News 2 09-29-2010 03:19 AM
Mineral Spirits- might not be a good additive diamondlarry General Fuel Topics 10 12-17-2005 03:52 PM
I was looking through my crx dealer brochure... bagpipe goatee General Fuel Topics 10 09-04-2005 04:51 PM
