i'm wondering if it will be possible to add a decent strut brace to my car.
the air filter is right on top of the engine, and i'm not sure if theres enough clearance to go above it. i was considdering making two braces to the firewall but i'm not sure if it's strong enough....although the towers are close enough to it so perhaps i could use two short braces that don't go all the way to the center and than connect these with a horisontal brace, although that might make things to complicate. i'd have to avoid the water reservoir and break pump on the right....
here's a picture of the engine bay
i really like the engine, it can take a lot, and once it's warm it's really mooth, but for a strut bar that air filter is pretty much an the way
unless i could go below it... there's some fuel lines there for the carb, but there might be enough room. also i'm wondering if i could use the existing screws on the towers to attach the braces to?
