digital clock in 1991 CRX HF - Fuelly Forums
Old 11-02-2007, 05:38 PM   #1
My HF doesn't have the digital clock in the middle console which I believe the Si version has. There are quite some people parting out Si's and I am thinking of getting one, but I wonder if anyone knows if the HF already has the connections for it and if it is just a question of removing the plastic piece and putting the clock in. Anyone know?
McPatrick is offline   Reply With Quote
Old 11-02-2007, 06:06 PM   #2
UfoTofU's Avatar
Did a quick search on HT and a few people have indicated that the plug should be right there.
I'd take a look for myself. Be careful when taking out the vent assembly, I broke mine and had to Krazy Glue little pieces of it all back together.
http://www.honda-tech.com/zerothread?id=1457127
- UfoTofU
UfoTofU is offline   Reply With Quote
Old 11-02-2007, 06:52 PM   #3
ajohnmeyer's Avatar
Send a message via AIM to ajohnmeyer
When I bought my HF the previous owner had put an SI dashboard in it with the digital clock, he said it all just plugged right in.
"I got 350 heads on a 305 engine. I get 10 miles to the gallon. I ain't got no good intentions." -The Drive By Truckers
Team OPEC Busters!
ajohnmeyer is offline   Reply With Quote
Old 11-02-2007, 10:39 PM   #4
Member
78si's Avatar
Its pre-wired, just get one from a junkyard.
78si is offline   Reply With Quote
Old 11-03-2007, 08:30 AM   #5
Thanks for the info! Just what I was looking for. I will start looking for the wires...
Old 11-03-2007, 09:32 AM   #6
GasSavers_bobski's Avatar
+1... The vent plastic is pretty brittle, and the metal clips that hold the vent in place don't pull out easily.
Pick up a set of little pointed probe things from Sears or where ever... Specifically a 90? angle one. It works nicely for reaching around the edge of the vent plastic and compressing the metal tabs that hold it in place.
I've got a spare dash sitting in the basement... I'll try to get some pics of the clock and vent removal.
Old 11-03-2007, 09:44 AM   #7
That would be great Bobski. I'm starting to get somewhat worried. Breaking the vent assembly wouldn't be worth having the digital clock to me...is there any way to get to the wires without removing the vent assy?
Old 11-03-2007, 02:23 PM   #8
You could remove the whole dash and reach up through the air handler (aka heater core) opening.
Even if you break it, it's not that big a deal... It's the little clip tab things that hold the face plate to the left/right vent louver assembly that break. You could simply glue the two back together once it's out. The tabs break because the metal clips that hold the whole assembly in the dash are attached to the louver block thing... Applying force to the face plate to try to remove the whole assembly stresses those little tab/clip things. Just put as little force on the face plate as you can get away with, and you should be fine.
Here's the vents with clock, and one of the probe things I was talking about. I couldn't find my right angle probe, so I used the hook version.
Start by removing the center console cover so you can see what you're doing.
As you'll see, there is a metal clip on each side of the vent. It's located to the side of the area between the vents and the little adjuster roller thing. Don't bother with the passenger side clip... I couldn't depress it far enough to release when I messed around with this earlier.
Slip your probe tool thing between the vent and dash, and depress the clip.
Carefully pull and/or pry the driver's side of the face plate away from the dash. This is where things generally break... Just make sure the tab is fully depressed and pray.
As you pull the vent out, it will seem to get hung up on something. It's the plastic wire harness holder on the back of the vent assembly.
Reach in and pop the wiring harness out of the holder if it hasn't already fallen out, and continue pivoting the vents out. The holder will probably get hung up on the edge of the dash... Force it a little and it will slip by.
Old 11-03-2007, 04:15 PM   #9
Great DIY Bobski! You should maybe post it under DIY as well. I will need to get some of those nifty little tools!
Old 11-03-2007, 05:51 PM   #10
cfg83's Avatar
bobski -
Classy job on the help pics/instructions.
Gallons per hour caprice General Maintenance and Repair 24 12-11-2007 07:41 PM
Always lookin for better MPG HEK Introduce Yourself - New member Welcome 1 06-28-2007 05:04 PM
Interesting article about aerodynamics McPatrick General Fuel Topics 0 06-23-2007 07:11 PM
VX Head Question GasSavers_scostanz General Maintenance and Repair 8 02-17-2007 04:27 AM
