Del Sol engine swap - Fuelly Forums
Old 04-07-2013, 07:19 PM   #1
Del Sol engine swap
I have a '95 del Sol S (1.5L non-VTEC). A year ago, I picked up a '95 Civic EX engine (1.6L VTEC - D16Z6 with a P28 ECU). The guy cut some of the wires on the harness when he pulled the engine.
I have not looked, since the car is at a friend's house (he is doing the swap for me). I think that the 1.5L harness has 2 sets of wires and 2 connectors to the ECU, whereas the 1.6L has 3 sets of wires and connectors. From what I understand, I can use the existing wires and connectors from the 1.5L on the 1.6L engine and ECU. I will need to install the 3rd set of wires and connector in order to make the VTEC system operate.
Engine swappers - is this correct?
Old 04-08-2013, 06:30 AM   #2
All the north American ecus had a 3 plug ecu. Here this might help.
http://technet.ff-squad.com/wiring.obd1.htm
The wiring should all be there other than v tech wire it's only 1 or 2 wires to run.
Rusty94cx is offline   Reply With Quote
Old 04-09-2013, 04:26 AM   #3
Thanks!
Old 04-09-2013, 11:44 AM   #4
No prob.
Old 04-23-2013, 02:37 PM   #5
How many wires are required for the VTEC actuator and where is it located in engine bay?
Old 04-23-2013, 07:24 PM   #6
Not sure think it's only one. The vtech solenoid is bolted to the valve cover on the dist side.
ECT Analyzer/manual TC lockup GasSavers_Bruce Transmissions and Running Gear 60 04-01-2008 11:37 AM
Affordable scanguage? lawnguybri General Fuel Topics 6 01-30-2008 07:22 PM
A RAV4 to go with the Prius? krousdb General Discussion (Off-Topic) 31 12-30-2006 05:32 AM
ROFL. Anybody see General tech??? Compaq888 General Discussion (Off-Topic) 15 09-03-2006 05:04 AM
