Originally Posted by Gary Palmer
I would think if you are going to soak the metal parts in something, that something like linseed oil or even some old motor oil would be a lot better than water. With my luck I'd put them in the water and forget about them until they had grown some nasty piles of rust.
Chances are these cars were not using Dot 5 brake fluid and were instead using Dot 3. Dot 3 brake fluid absorbs water. It does this to assimilate small amounts of water that can get into the brake system.
The brakes on this car have been sitting for years, and there was very little fluid leakage when I unbolted the lines. More than likely there is crystallized brake fluid in the cylinder bores and on the seals. Soaking the parts in water for about 24 hours should rehydrate the crystals and free everything up. I hope I can knock the pistons out of the cylinders when I get home tonight and inspect the bores for damage.
I will be converting to Dot 5 brake fluid on this restoration, which is a silicone based fluid.
Here are pictures from this weekend:
Thick bondo chip from the roof skin.
Roof skin after bondo was chipped away.
This is how she sits now.
Headliner removal tools.
Interior pre-gutting.
Interior post-gutting.
Brake calipers (x2) and wheel cylinders (x4)
Front corner minus brake components.
All that is left from the yellow car.
My first one, tucked away in the corner still.
