D15Z1 Engine swap project log - Page 26 - Fuelly Forums
Old 08-13-2006, 01:59 PM   #251
Where's my throttle cable, Joke joke, need to not waste money if I'm gonna fix my wheel bearing...
Old 08-13-2006, 02:13 PM   #252
krousdb's Avatar
The transmission is still leaking, rather badly I think. I need to remove the axle tomorrow and replace the axle seal.
Those seals are hard to find. You can't get them at Autozone or Pep Boys. I had to get one from Honda for around $9. Im assuming you have the VX tranny.
Old 08-13-2006, 02:15 PM   #253
HF tranny, want me to send you one, matt? I've got tons!
Old 08-13-2006, 06:50 PM   #254
Moderator
GasSavers_DaX's Avatar
I'd use a brand new one...not an old one. Just go to honda and shell out the $9...it will be worth it in the end.
Old 08-13-2006, 07:03 PM   #255
Matt Timion's Avatar
I got mine from Honda too...
I actually replaced it when the engine was out of the car, but apparently I didn't replace it correctly.
I'll try to fix it myself, and if that doesn't work I'll shell out the money for another new one.
Oh, and SVOBoy is right. I have a HF Transmission. THe 92+ transmissions don't fit in the 88-91 hondas, at least not directly.
Old 08-14-2006, 09:34 PM   #256
Speedometer doesn't work.
ARGH!
THe cable is hooked up properly, but I think I may have loosened the vehicle speed sensor last month when I was trying to remove it. I'm guessing it's not all of the way "in" now.
Hopefully I can easily tap it into place.
Old 08-14-2006, 09:40 PM   #257
You'll get it! It's prolly just slipped out, hopefully not broken,
Old 08-14-2006, 09:50 PM   #258
Considering how much I pulled and yanked on it I'd be surpised if it slipped out.
Old 08-17-2006, 03:14 PM   #259
Okay... I put a new axle seal on and it didn't help... leaked a ton of oil...
upon further inspection I realized I put both of the axle seals on incorrectly, so I'm going to redo it aagain in a little while.
Also figured out that my new speedo cable is broken. I managed to fix my old one, so it will go in tonight.
Learn from my mistakes people...
Old 08-17-2006, 03:15 PM   #260
The teg cluster beckons you!
Gearbox dropdown greyed out; missing engines? synergist Fuelly Web Support and Community News 2 09-05-2013 07:48 AM
Small issue with fuel entry, leading zero metalfan49 Fuelly Web Support and Community News 1 08-07-2013 07:08 AM
The Honda Fit GasSavers_DaX General Fuel Topics 54 05-13-2006 12:52 AM
