D15Z1 Engine swap project log - Fuelly Forums
Old 06-30-2006, 01:26 PM   #1
Matt: I don't mean to be a pain ITA, but their are a number of thing's it could be or is, still. Timing isn't that tough, but you will have to get back to basics and go through, methodically, one step at a time, to create a foundation.
It has to be hot, and that sun can be a cooker.
Did you try spraying carb cleaner down the throat of the intake?
I know you presumed your timing belt was Ok, don't, check it out. Make sure that it's lined up, in the right orientation. Last belt I did, I got it on, off one tooth, 180 degrees out and it took me 2x through to figure out what I was doing to shoot myself in the foot.
Set up your distributor, like I described.
Check the wiring. Check the plugs.
p.s. try not to be to short or harsh on the people trying to help you and encvourage you.
Old 06-30-2006, 01:30 PM   #2
Matt Timion's Avatar
Good advice. I should just not post until I've had food, as I tend to be a bit short with people when I'm hungry. My apologies.
I'm going to try using carb cleaner to see if I can get it started that way. I'll then take the timing belt cover off and make sure it's all lined up correctly. After that I'll double check the distributor wiring as well as the fuel injector wiring. Never hurts to check again.
Thanks everyone for the encouragement.
Gearbox dropdown greyed out; missing engines? synergist Fuelly Web Support and Community News 2 09-05-2013 07:48 AM
Small issue with fuel entry, leading zero metalfan49 Fuelly Web Support and Community News 1 08-07-2013 07:08 AM
The Honda Fit GasSavers_DaX General Fuel Topics 54 05-13-2006 12:52 AM
