06-30-2006, 11:06 AM
Moderator
The distributor can only go on one way.
I was talking about mechanical timing, not electrical. The car will run with very poor electrical timing, but if your mechanical timing is off even a little (ie - timing belt off a tooth or more), you're car likely won't run. I've been able to drive a Civic with the timing belt off one tooth, but not one with the timing belt off two teeth.
