D15Z1 Engine swap project log - Page 20 - Fuelly Forums
Old 06-30-2006, 08:43 AM   #191
The reason he said about in gear was because his clutch cable might not be tight enough to throwout completely.
EDIT: I suck.
Old 06-30-2006, 08:43 AM   #192
If it is a new seal, you should be able to use a 2x4 and a mallet to just go around the outer edges of the seal and tap them in. Also, since you didn't use the regular fill hole, you may have just overfilled the transmission, and the seal is leaking because the oil level is just to high.
Old 06-30-2006, 08:44 AM   #193
On the clutch, the switch is inside the car, actuated by the clutch pedal, not by the clutch itself.
Old 06-30-2006, 08:46 AM   #194
Do EFs have a clutch switch?
Old 06-30-2006, 08:49 AM   #195
Matt: All I'm trying to say is that the motor should start, irrespective of if the clutch is hooked up or adjusted properly, or not. The switch that Honda uses, on a manual transmission is activated by the clutch pedal, independent of the clutch cable adjustment. You would still have to get the clutch adjusted properly to drive, of course.
Old 06-30-2006, 08:51 AM   #196
But if his car is in 5th or something and in gear the engine won't be able to start up because it well be trying to move the wheels as well, correct? I've accidently done it in reverse and it jumped, but I don't think it would have enough torque in fifth to get it going.
Old 06-30-2006, 08:51 AM   #197
If I understand correctly, he has an 89, previously with a DX transmission, swapped to an HX. If that is the case, then YES, it very definitely uses the clutch switch. (I was under the dash on mine a couple of days ago, working on my Codfishing outfit).
Old 06-30-2006, 08:52 AM   #198
Ah, that's true, I forget. I have the switch on my pedals I just never got a plug and hooked it up, so I don't have one,
Old 06-30-2006, 08:53 AM   #199
Matt Timion's Avatar
Yes... we seem to have a communication issue.
If the car is IN GEAR it will have a more difficult time starting.
If my clutch cable isn't tight enough and the transmission is IN GEAR it actually won't be in nuetral when i start it. This is true regardless of the electronic switch at the clutch pedal.
I'm thinking entirely of the mechanical aspect of the engine starting, not electronics.
It doesn't matter much anyway because the first thing I'm going to do is tighten the clutch cable and get the shift linkage put back together so that this isn't a concern any more.
Old 06-30-2006, 08:53 AM   #200
Ok, so what your saying is he might have it in gear? You could be right, but if he put's it into neutral, then it shouldn't matter. ( I'ts interesting the things I take for granted because I would have put it into neutral, automatically).
Gearbox dropdown greyed out; missing engines? synergist Fuelly Web Support and Community News 2 09-05-2013 07:48 AM
Small issue with fuel entry, leading zero metalfan49 Fuelly Web Support and Community News 1 08-07-2013 07:08 AM
The Honda Fit GasSavers_DaX General Fuel Topics 54 05-13-2006 12:52 AM
