06-28-2006, 07:47 PM
No dice.
I installed the axles and then took the one bolt off holding the VSS in place so that I could fill the transmission with fluid.
The bolt came off, the little metal thing came off, and the VSS wouldn't budge.
Turns out I was supposed to remove it BEFORE I put the engine in.
So I tried to remove the fill hole, but it seems that after 160k miles that bolt doesn't want to move either. I sprayed it with PB Blaster and tomorrow will try to use the vice grips on it. Hopefully either hte VSS or the fill hole will budge and I'll be able to fill er up.
That being said, where do I get one of those cool caps with the clear vinyl tube coming out so that I can fill my transmission up?
