06-26-2006, 08:55 AM
Originally Posted by Gary Palmer
Matt: You know when I suggested you just buy the hoist, I did not really intend for you to keep using it, so frequently. Did you get the crank pully swapped? On your crank bolt, I would think it might be the same size as the one of your old engine? You mentioned you could only get two bolts in on the power steering pump, it might be Ok, but my concern would be having a bolt bust the block, due to not enough bolt's. I would either use all 4 bolts or mount the pump, but don't put on the belt. Worst case, you can drive it without the pump, it is just a lot harder to turn, since the turn's ratio is much higher. Good Luck
On the sun, if you can find a way to swing it, you need to get one of those pop-up shade canopies, they help immensley
LOL
I'm actually thinking of getting a giant drill bit today to widen the holes a little bit on the power steering bracket. that should enable me to get the bolts in alright.
Or, i cna just hacksaw the top part (the part that connects to the engine mount a little so it will fit correctly.
