06-20-2006, 01:58 PM
Can I tap the purge solenoid into E (above) with a t-connector?
Yup.
Vacuum is vacuum.
So whether you take it straight off the intake from a nipple or install a T and share the vacuum with another source it should all be the same.
I would just use a cheap vacuum T if I were you. WAY easier than tapping a new port.
Nice TPS and IAT sensors by the way  Where'd you buy that engine from?
