D15Z1 Engine swap project log - Fuelly Forums
Old 06-09-2006, 07:55 AM   #11
Matt:
In thinking about it, I have a observation/suggestion. When you pulled the motor, I think that one reason you may have had it tight is that you pulled it straight up, it look's like, from your picture's. What I would suggest when you put it back in is to use the balance bar to set it so the transmission is hanging down, to the left, and the front of the motor is hanging up and to the right. Then you just bring it down into the engine bay and using the balance beam, bring the center of gravity back towards the middle, so that the front of the engine swing's down and in and the transmission come's up and in. Hope maybe that will help some.
Gearbox dropdown greyed out; missing engines? synergist Fuelly Web Support and Community News 2 09-05-2013 07:48 AM
Small issue with fuel entry, leading zero metalfan49 Fuelly Web Support and Community News 1 08-07-2013 07:08 AM
The Honda Fit GasSavers_DaX General Fuel Topics 54 05-13-2006 12:52 AM
