D15Z1 Engine swap project log - Fuelly Forums
Old 06-08-2006, 06:23 AM   #10
Matt Timion's Avatar
Originally Posted by DaX
There are four 12 mm bolts (very long) that hold the compressor to the bracket. They are between the radiator and the compressor. Take the bottom ones out first, or you'll be sorry. Two on top, two on bottom.
Once you unbolt the compressor, you can simply let the compressor sit on the front crossmember, or if you decide to remove the front crossmember, you can zip tie the compressor to one of the hard lines on the chassis nearby (what I currently have done for my 5-spd conversion).
Cool. Just looked at the helms and it looks good. I'll be going out shortly to try to remove it, just as soon as I get my coffee.
Gearbox dropdown greyed out; missing engines? synergist Fuelly Web Support and Community News 2 09-05-2013 07:48 AM
Small issue with fuel entry, leading zero metalfan49 Fuelly Web Support and Community News 1 08-07-2013 07:08 AM
The Honda Fit GasSavers_DaX General Fuel Topics 54 05-13-2006 12:52 AM
