D15Z1 Engine swap project log - Page 29 - Fuelly Forums
Old 09-26-2006, 08:30 AM   #281
Matt Timion's Avatar
Just put in an order for a new oxygen sensor from www.oxygensensor.net.
I feel kind of weight dropping $180 on a car that I'm going to sell soon, but I'm almost positive the low MPG is due to the used oxygen sensor on this car. The guy who sold it to me said it had 160k miles on it. I'm pretty certain with the new o2 sensor I can get the MPG up to 45mpg easily, which will make this car that much easier to sell.
Old 09-27-2006, 04:15 PM   #282
Whats the difference between the California and the non-California VX?
I am from california and i bought an ecu thats not from california. Im guessing that theres also a difference inside of the ecu if its a california model but i have no idea what it is. Does anyone know what it is?
How would i know that the ECU is not from California or that it is?
8Civic8 is offline   Reply With Quote
Old 09-27-2006, 06:52 PM   #283
DOn't know how to tell the difference, but I can tell you the difference in operation.
The CA model used a 4-wire o2 sensor and doesn't have lean burn at highway speeds. The non-CA model used a wideband o2 sensor (5 wires) and has lean burn.
Check www.fueleconomy.gov and notice the different EPA estimates for the two models.
Old 09-28-2006, 04:19 AM   #284
Moderator
GasSavers_DaX's Avatar
If the CA model does not use a wideband and only uses a narrowband, then you can tell the difference in ECU's by opening them up and looking to see if it has two processor chips. If there are two processor chips, then you have the lean burn ECU that works with the wideband (5-wire).
Old 09-29-2006, 09:19 PM   #285
How do the processors look. I opened my ecu up my ecu and it looks just like the following P28, its identical same chips and everything (Except that it doesnt have that programmed chip in the lower right hand corner, im guessing thats what you burn and solder on the ecu)
(NOTE: I Know nothing about ecu's other than ive got one that is a #####-P07-L02)
Ive read somewhere, i think rywire.com, that the L means california? Doest the fact that i have one that looks just like a p28 and has an L02 mean that i have a 4 wire o2 sensor? ( i need to buy an o2 sensor and i wanna make sure)
Edit:
K, heres a picture of my own ecu, i just took it appart and took a pick of it. (dont mind the date this was a few minutes ago). What do you guys think, its almost identical to the one above.
Old 09-29-2006, 10:14 PM   #286
I think the best bet is probably to email Ryan at rywire. He can most certainly tell you if your ECU is a CA model or not based on your ECU code.
Old 03-11-2007, 05:31 PM   #287
kwtorbe's Avatar
After wasting all day on this, I am finishing up and I notice my cylinder cover bolt keeps spinning.
Yep. You guessed it. Busted.]
Can anyone recommend what to do about this hole? I would use epoxy or something (as I have the piece that broke off as well) but I'm afraid it will fall off again and screw with my rocker arms.
I had a similar issue. I had a valve vover bolt break off in my head (cylinder head of course ) I just used silicone and the broke bolt as a plug and I didn't get any valve cover leaks. Good work. I just spent 45 minutes reading this thread......
kwtorbe is offline   Reply With Quote
Old 03-12-2007, 07:56 AM   #288
GasSavers_TomO's Avatar
8Civic8, check your ECU label HERE. That is all the info to tell what ECU you have and emissions type and everything.
Honda Civic VX Info/Links
Old 09-13-2007, 09:17 PM   #289
Member
78si's Avatar
I'm almost done swaping my VX into my 88 hatch. I even bought the vx wheels. I'll start a thread when I'm done.
78si is offline   Reply With Quote
Old 10-02-2007, 03:37 PM   #290
MakDiesel's Avatar
Same here, but in my '89 CRX HF, and I've only got steelies for now. I just hope you didn't take as long as I did to complete the swap (It will be 2 years in mid-Oct., but that counts the whole tear-down and rebuild, and technically the swap has been all done since April, she fires alright, purrs and screams proper). I dunno about a thread, I've got to much crap going on to even update my gas log, much less pictures and details. Looking forward to yours though...maybe one day I'll get mine done...Mak
'85 CRX Si Original EW3 @ 254k...suck it Detroit
'89 CRX HF-Z1 ~ When haste is needed
'97 Civic DX Hatch ~ Formerly 600hp, now 0hp, soon 115hp.
MakDiesel is offline   Reply With Quote
Gearbox dropdown greyed out; missing engines? synergist Fuelly Web Support and Community News 2 09-05-2013 07:48 AM
Small issue with fuel entry, leading zero metalfan49 Fuelly Web Support and Community News 1 08-07-2013 07:08 AM
The Honda Fit GasSavers_DaX General Fuel Topics 54 05-13-2006 12:52 AM
