D15Z1 Engine swap project log - Page 21 - Fuelly Forums
Old 06-30-2006, 08:54 AM   #201
Ah well, enough questions and we'll get their, I guess. Good Luck
Old 06-30-2006, 08:55 AM   #202
Matt Timion's Avatar
see post above
Unless my transmission is actually in gear, which it probably is. I havn't hooked up the shift linkage yet. If the clutch cable isn't engaging the clutch then it is not going to really be able to start because it isn't in nuetral.
So add getting the shift linkage put back together to the list.
Old 06-30-2006, 08:57 AM   #203
You can hop under the car and put it in neutral manually.
Just stick a screwdriver through the hole and move it in betwixt in the 3 positions.
Old 06-30-2006, 09:00 AM   #204
Matt: My problem wasn't that I didn't understand your note. From what you described, unless you have the front on the ground, worst case, the wheels would just turn. If it was hung up because of being in gear, you'd just hear a big "thunk" sound, when you tried to start it, and the engine would not turn over, at all.
Old 06-30-2006, 09:11 AM   #205
Very true. Communication issue could very well be on my part. I seem to be making up terms as I go along and finding out that the terms already have another meaning
Old 06-30-2006, 11:06 AM   #206
Okay...
Car is in nuetral. clutch cable is tightened properly. It is no longer dripping transmission fluid, which means it either mananged to drip all 1.9 quarts in about 12 hours or it was just overfilled and was expelling the extra. Maybe I'll remove the reverse light switch and put a dipstick in there to check if there is any fluid.
THe engine cranks. I marked the power steering belt and it definately moved. Now I have to check for spark. I tried putting a spark plug on the end of a spark plug wire and tried cranking it. I saw no spark, but then again it could be that the brightness of the sun prevented me from seeing it.
Is there an easy way to check for spark? Say, with a multimeter?
The rotor is on the distributor, but if it's giving me problems I'll just swap with the spare distributor I have in the garage.
Old 06-30-2006, 11:06 AM   #207
Moderator
GasSavers_DaX's Avatar
The distributor can only go on one way.
I was talking about mechanical timing, not electrical. The car will run with very poor electrical timing, but if your mechanical timing is off even a little (ie - timing belt off a tooth or more), you're car likely won't run. I've been able to drive a Civic with the timing belt off one tooth, but not one with the timing belt off two teeth.
Old 06-30-2006, 11:25 AM   #208
Huh? I asked if there is another way to check for spark, not if the distributor is put on improperly.
Of course this is something I should have done when the engine was out. When I replaced the timing belt I left everything as it was. Nothing moved. I can assume that nothing was messed up.
I'll ensure that I have spark first before I worry about mechanical timing, which sound like a PITA.
Old 06-30-2006, 11:29 AM   #209
Moderator
Were you grounding the plug when you had it in the end of the wire? It needs to be grounded - I touch the plug to a valve cover bolt. You may need to wait for dark to see the spark, but you shouldn't...I've seen it in daylight.
Old 06-30-2006, 11:32 AM   #210
Word. I'll do this when it's no so freaking hot outside.
Gearbox dropdown greyed out; missing engines? synergist Fuelly Web Support and Community News 2 09-05-2013 07:48 AM
Small issue with fuel entry, leading zero metalfan49 Fuelly Web Support and Community News 1 08-07-2013 07:08 AM
The Honda Fit GasSavers_DaX General Fuel Topics 54 05-13-2006 12:52 AM
