D15Z1 Engine swap project log - Page 17 - Fuelly Forums
Old 06-28-2006, 09:55 AM   #161
Thumbs up
BTW, is it possible for me to just buy the pieces and make my own hose with parts at PepBoys or Home Depot? I'm not opposed to that.
Matt: That line is a high pressure fuel line, for the injector's. The "stores" will tell you that you can't, it will leak, blah, blah, blah.
Baloney! You can cut off the crimped connector, rearrange or reorient the hose and put a worm screw clamp on it. I've put several on different cars and I haven't had them leak. The only thing to be mindful of is that it's preferable to have some barb thingies, I can't think of the right term, on the tubing, for the hoses to grip on, when you tighten down the hose clamps. If you want to be extra cautious, if you can get enough hose on the tube, use two clamps on each connection.
Good Luck!
Old 06-28-2006, 10:01 AM   #162
MakDiesel's Avatar
I'm guessing you'll sell it all as a unit but if not I could really use the ECU (P07?) and wiring. I picked up a Z1 last week w/ side mount, intake box, and 4-wire O2 (California model? In North Carolina?) I still need the EGR box, a wiring conversion, and....eh it's all in my signature. Funny story about that engine...http://www.redpepperracing.com/forum...howtopic=26783
Mak
'85 CRX Si Original EW3 @ 254k...suck it Detroit
'89 CRX HF-Z1 ~ When haste is needed
'97 Civic DX Hatch ~ Formerly 600hp, now 0hp, soon 115hp.
MakDiesel is offline   Reply With Quote
Old 06-28-2006, 10:29 AM   #163
Matt Timion's Avatar
Mak
Heh... I post on redpepperracing sometimes too. My wife (jenny on this forum) has a 87 CRX Si and repepperracing is my best friend when it comes to that car.
Oh yeah, California VXs pop up everywhere, even north carolina.
Old 06-28-2006, 10:42 AM   #164
MakDiesel's Avatar
The Swap List
Truer words never spoken...I've been helped by that site on my '85 CRX Si more than I can possibly remember. It is THE site for '84-87 Civic/CRX Hondas.
I have a request: I wanted to know what else I needed to gather before embarking on my own HF-Z1 quest. I have the engine (looks like all sensors, pan to the manifold complete, one side mount, stock intake box) and HF tranny (shift linkage, tranny, starter, HF flywheel). After rereading this thread a couple times, I've made a list for myself and anyone else who might want to follow you and Bunger:
1.) P07 ECU
2.) EGR box exculsive to the VX
3.) ECU conversion harness (I don't have the skills for that many wires yet)
4.) obd1 plugs for the distributor, VTEC, and VTEC oil pressure solenoid
5.) 5-wire O2 (mine came with a 4-wire, could possbily run the last one from the ECU?)
6.) driver's side mount from an obd1 car (got)
7.) 92-95 Civic HELMS Manual
8.) engine hoist
9.) anything else? (fuel lines different?)
My only other notes are I won't be running power steering (HF doesn't stock) or A/C (I can deal w/ windows down + tint). Keeping this list will cut prep time and especially install time if I have everything I need on day one of the swap. Thanks for any input, Mak
Old 06-28-2006, 10:57 AM   #165
1.) P07 ECU
8.) engine hoist
I'll make a list for you later this afternoon. Don't buy anything yet
Old 06-28-2006, 11:08 AM   #166
Moderator
GasSavers_DaX's Avatar
Do you have two fuel lines? If so, cut them in half and use the two ends you want - splice them together with a piece of metal and two hose clamps. Not clean, but it works! I've had to do this before...I think I used a leftover piece of metal from the hard coolant line that also has the hard air line that goes from the intake tube to the valve cover.
Old 06-28-2006, 04:59 PM   #167
Just got back from the junkyard. The fuel line from the 89 CRX HF works perfectly. Mak, I'll respond to you after dinner.
Old 06-28-2006, 07:47 PM   #168
No dice.
I installed the axles and then took the one bolt off holding the VSS in place so that I could fill the transmission with fluid.
The bolt came off, the little metal thing came off, and the VSS wouldn't budge.
Turns out I was supposed to remove it BEFORE I put the engine in.
So I tried to remove the fill hole, but it seems that after 160k miles that bolt doesn't want to move either. I sprayed it with PB Blaster and tomorrow will try to use the vice grips on it. Hopefully either hte VSS or the fill hole will budge and I'll be able to fill er up.
That being said, where do I get one of those cool caps with the clear vinyl tube coming out so that I can fill my transmission up?
Old 06-28-2006, 07:49 PM   #169
Get the cap at autozone, that or the cone with the flexible hose and on/off valve.
You could shove some in the axle holes,
Old 06-29-2006, 03:50 AM   #170
Moderator
I would recommend filling at the VSS...MUCH easier. Remove the VSS bolt, then get some small channel locks and GENTLY grab the VSS at the base and twist. It should break loose.
You'll also want to remove the fill hole bolt so you know when it's full (oil coming out). Be sure and fill on level ground with the car on the ground.
Gearbox dropdown greyed out; missing engines? synergist Fuelly Web Support and Community News 2 09-05-2013 07:48 AM
Small issue with fuel entry, leading zero metalfan49 Fuelly Web Support and Community News 1 08-07-2013 07:08 AM
The Honda Fit GasSavers_DaX General Fuel Topics 54 05-13-2006 12:52 AM
