D15Z1 (Civic VX) - clutch sensor ? - Fuelly Forums
Old 06-07-2008, 06:44 AM   #1
VEI
VEI's Avatar
Hello.
What is the function of the litle sensor on the clutch pedal ?
VEI is offline   Reply With Quote
Old 06-07-2008, 07:11 AM   #2
Shot in the dark guess: Clutch-start lockout so you can't crank the starter without pushing the clutch pedal.
Old 06-07-2008, 07:23 AM   #3
VEI
VEI's Avatar
My Civic is a european model. I have this sensor but I can start the engine without pushing the clutch pedal
So, no other function?
Old 06-07-2008, 07:54 AM   #4
I think there might be either one or two switches on the clutch pedal, depending on the model. One is called the clutch interlock switch. Like holy said, it's designed to prevent you from engaging the starter unless the pedal is down.
There could be another switch on the pedal, which has to do with the cruise control system. Of course a US VX doesn't have cruise, but maybe your VEI does. And maybe Honda decided to put the cruise-related switch on there even if your model doesn't have cruise.
I'm surprised you can start your car with the clutch up. I wonder what your owner's manual says about that. I think in the US manual it indicates that the pedal must be down.
Old 06-07-2008, 08:07 AM   #5
It would be really annoying to find out that clutch-start interlock is not required outside of the US.
Old 06-07-2008, 08:17 AM   #6
VEI
VEI's Avatar
monroe74, no cruise control system on european Civic.
The Civic VEi (D15Z1 engine) is the only one to have this sensor on the clutch pedal.
And nothing in the owner's manuel.
Old 06-07-2008, 10:45 AM   #7
I just sort of assumed all cars are made that way these days, but maybe that's a silly assumption on my part. It just seems like a very rational safety feature.
That's an interesting mystery. Maybe Honda put the switch on your model for no good reason. I think that sort of thing happens sometimes, deliberately, as a way to simplify manufacturing. Leaving the item in the design, if it's used on other cars, might be easier than deleting it from the design. Just a guess.
Old 06-07-2008, 10:18 PM   #8
suspendedhatch's Avatar
On some P07 pinouts that I've seen, the ECU actually has a clutch input. There are several functions for having a clutch input to the ECU. The example that comes to mind right now is a fuel and/or ignition cut when you put the clutch in.
Mine didn't have it but I wired it in to my AEM EMS so I could have WOT shifting and a 2 step rev limiter.
Old 06-08-2008, 07:49 AM   #9
GasSavers_Ryland's Avatar
It's so the ecu knows when the clutch is being pressed so that it can start injecting fuel again when you press the clutch in if you are coasting in gear and the fuel has been cut.
Keeping the Automatic Cool rh77 Transmissions and Running Gear 27 01-13-2008 05:18 PM
1995 Geo Metro 2dr hatch in MN GasSavers_TomO For Sale 3 09-25-2007 09:28 AM
ultra quick bike conversion skewbe Electric and Solar powered 13 08-24-2007 05:21 AM
