CRX Master Cylinder? - Fuelly Forums
Old 08-28-2008, 06:50 PM   #1
mrmad's Avatar
So if I'm sitting on a downhill stoplight, the brake pedal slowly sinks toward the floor, meaning I have to apply more pressure to keep the car stopped. If I let go of the pedal and apply the brakes again, its engagement point is normal, and overall the pedal feels normal and the brakes seem as strong as they ever have.
I checked the fluid and it is at the full mark. Seems to me this is my master cylinder leaking a little. Any opinions?
Thanks for your help.
Old 08-28-2008, 07:03 PM   #2
GasSavers_Erik's Avatar
Yes- that's the classic sign of a master cylinder internal seal leaking- Pedal sinks under light pressure, holds better under heavy pressure.
The internal seal leak just lets the brake fluid pressure back into the reservoir. Overall no fluid is lost.
Better fix it ASAP or you might rear end someone...
Old 08-28-2008, 07:12 PM   #3
Loserkidwac's Avatar
Send a message via AIM to Loserkidwac
Yup, just had to do it on the Del Sol, make sure you bench bleed the new MC, and if your fluid is dirty its a good time to bleed the whole system...if you do that make sure you do them in the correct order! GL Matt
MPG Noob
03 Mazdaspeed Protege
91 Honda CRX Si
95 Honda Civic VX *RIP 5/20/08
94 Honda Del Slow D15z1 Swapped
Loserkidwac is offline   Reply With Quote
Old 08-28-2008, 07:18 PM   #4
Jetta90GL's Avatar
The seals on the master cylinder plunger are getting worn out and allowing fluid to leak past. Pumping the pedal will help build up pressure. The only way to fix it is to replace the entire master cylinder. I have drove quite awhile like that just double pumping all the time, but that does put a lot at risk.
-Edit .. i guess i didn't type fast enough before the other replys
Jetta90GL is offline   Reply With Quote
Old 08-28-2008, 07:30 PM   #5
mrmad's Avatar
Thanks guys, that's kind of what I thought but didn't want to replace it for nothing.
No MPG on next tank after partial fuel-up ? insightfulone Fuelly Web Support and Community News 1 04-18-2010 12:54 PM
Retire a Vehicle pb Fuelly Web Support and Community News 1 11-11-2008 04:30 PM
Just installed my new NTK 5 wire o2 sensor. 92VXHatchguy General Maintenance and Repair 7 08-27-2008 03:33 PM
Family Carpooling BumblingB General Discussion (Off-Topic) 2 06-07-2008 01:37 PM
Socal Yaris driver In N Out Introduce Yourself - New member Welcome 6 04-11-2008 06:22 PM
