CRX HF Tranny Question - Fuelly Forums
Old 08-22-2008, 03:02 PM   #1
I am placing a d15z1 (vx) engine in my 90 DX hatch. I have access to a CRX HF tranny, '91 I believe. Will I be able to use the clutch, linkage, torque converter, etc. from my DX , or will I need to get this from another car?
hunterhound is offline   Reply With Quote
Old 08-22-2008, 04:18 PM   #2
GasSavers_Erik's Avatar
I'm not sure about compatibility, but you shouldn't need a torque converter
Seriously, you can put both cars into autozone.com and cross reference the part numbers.
Old 08-22-2008, 04:53 PM   #3
Member
Yes, everything is the same, but like Erik said, no torque converter. Thats exactly the same swap I did.
nowhhs is offline   Reply With Quote
Old 08-24-2008, 10:33 PM   #4
If your hatch is already manual it should be an fairly simple swap. The trans should bolt right in. As long as the tranny's not an 87(maybe 88 not sure) or older your fine.
GasSavers_topher is offline   Reply With Quote
Looking for an econo box ? GasSavers_ALS General Fuel Topics 4 04-07-2008 02:39 PM
E-85 and EPA rating zpiloto General Discussion (Off-Topic) 7 09-26-2006 07:04 AM
Evo-Style Vortex generators? cfg83 Aerodynamics 5 09-21-2006 11:09 AM
Free flow exhaust GasSavers_Kraig General Fuel Topics 9 08-07-2006 08:53 AM
