Cross-Ventilated Rotors. Worth It? - Fuelly Forums
Old 07-15-2012, 06:42 PM   #1
Are Cross-Ventilated Rotors worth the cost?
I'm about due for pads and because there is a slight vibration from a hot spot on one of the rotors I may replace the rotors rather than turn them.
I often carry large payloads but, more importantly my stopping involves long periods of gentle braking, empty or loaded, rather than hard braking.
Old 07-15-2012, 11:45 PM   #2
GasSavers_JoeBob's Avatar
Re: Cross-Ventilated Rotors. Worth It?
Have you had problems with brake fade?
I would think that anything that will lower braking temperatures would be worthwhile, especially if you spend as much time driving as you do.
Old 07-15-2012, 11:56 PM   #3
Never faded. Mechanic said the reason for the vibration was that I didn't break-in the last set of pads.
Old 08-23-2012, 02:46 PM   #4
Maybe in that case, but I know from road course racing (different use of the brakes, I know), that a lot of people had problems with cross-drilled rotors. I had slotted rotors at one point on the front of one of my cars, but they were more expensive & will eat through pads faster.
Do you have a link to the rotors you were thinking of purchasing?
notorious_eg is offline   Reply With Quote
Old 08-23-2012, 05:54 PM   #5
Dex, my carfixer, installed ceramic pads and new rotors of the stock variety. Everything is working splendidly.
Howdy! es330td Introduce Yourself - New member Welcome 1 11-20-2007 03:03 PM
adjusting the ignition timing via the map sensor. csrmel Experiments, Modifications and DIY 9 11-09-2007 10:08 PM
