Converting '86 HF (carb) to fed VX (efi). - Page 2 - Fuelly Forums
Old 02-13-2008, 09:23 PM   #11
GasSavers_Ryland's Avatar
I don't know where you got the specs for your '86 crx hf engine from, but I have that exact engine sitting on the bench in the garage right now, and it is a cvcc head, the only 1984-87 crx that didn't have a cvcc head was the 1.3L and the SI modle, the DX and HF both have CVCC heads, so for fuel injection you are going to need a whole head, you are most likely going to need the head off the SI engine to get one fits right, and I'm not sure wha they use for crank shaft position sensor, CPU, and all that.
Who did your carb rebuild?
Old 02-14-2008, 02:16 PM   #12
I'll pop the carb (and valve cover) off this weekend and take pictures so we can get the CVCC question settled. You guys might be right.
This is my first venture into pre-OBD1 land...
Colby is offline   Reply With Quote
Old 02-14-2008, 02:30 PM   #13
GasSavers_Erik's Avatar
If its a CVCC, the 3rd barrel will be a dime sized hole off to the driver's side of top of the carb. After you get the air cleaner off, you will likely need to take the intake screen off the top of the carb to see the small third barrel (if its like my carb).
Another CVCC indicator- when you take off the valve cover, you will actually see 1 tiny valve stem/rocker assembly for each cylinder.
Old 02-14-2008, 03:18 PM   #14
cvcc honda engines also have the spark plugs coming out right over the exaust manifold, on the front side of the head, not the top of the head, about an inche below the lip of the valve cover, they are like this because they are in the prechamber next to that little auxilery valve, it's a great design, and I'm not sure if you can get better gas mileage with fuel injection, not easly at least, but I've rebuilt these carburators a number of times, and I'm a big fan of them, but I know what it's like to have problems.
Old 02-16-2008, 03:21 PM   #15
It's a CVCC alright. Guess I'll just have to keep fussing with the carb and maze of vacuum lines =/
FOR SALE Modify NGK V-power spark plugs holypaulie For Sale 1 10-25-2007 07:55 PM
Warning to my NJ buddies... unstable bob General Discussion (Off-Topic) 9 09-21-2007 06:46 AM
US Forest chief: Use trees to make ethanol repete86 Automotive News, Articles and Products 3 09-13-2007 05:36 PM
Drove first hybrid-real eye opener tulsa_97sr5 General Fuel Topics 8 07-09-2007 11:51 AM
Google Earth Help GasSavers_DaX General Discussion (Off-Topic) 5 06-21-2006 11:44 AM
