Convert Civic CX to VX question? - Fuelly Forums
Old 09-06-2010, 05:24 PM   #1
I have a CX that is in need of a rebuild soon. I would like to turn it into a vx. (for mpg) My question is can I turn my block into a VX by installing vx pistons and getting a Z1 head?
I guess my question in a nutshell is, is a CX and VX block the same? I know the pistons and head is different. Anything else?
P.S. I know I would also need to change my 02 to 5 wire and get a vx ecu and possibly intake manifold?
klipsch21 is offline   Reply With Quote
Old 11-15-2010, 04:43 AM   #2
Dalamar's Avatar
Send a message via AIM to Dalamar
Re: Convert Civic CX to VX question?
Your CX has a D15B7
* Displacement : 1,493 cc (91.1 cu in)
* Bore and Stroke : 75 ? 84.5 mm (3.0 ? 3.33 in)
* Compression : 9.2:1
* Power : 102 hp (76.1 kW, 109 ps) @ 5900 rpm (102 hp @ 5900 rpm in U.S.)
* Torque : 98 ft?lbf (13.5 kg/m, 133 Nm) @ 5000 rpm
* Valvetrain : SOHC (4 valves per cylinder)
* Cam Gear: 38 Tooth
* Piston Code : PM3
* Fuel Control : OBD-1 MPFI
* ECU Code: P06
* Head code: PM 9-6
and a VX is running a D15Z1
* Rod Length : 137 mm
* Rod/Stroke : 1.62
* Compression : 9.3:1
* Power : 90 hp (67.1 kW, 91.3 ps) @ 5600 rpm (92 hp @ 5500 rpm USDM)
* Torque : 98 ft?lb (13.5 kg/m, 133 Nm) @ 4800 rpm (97 ft?lb @ 3000 rpm USDM)
* Valvetrain : SOHC VTEC-E (USDM- Lean Burn Federal Emissions 49 State) (3-4 valves per cylinder depending on RPM)
* VTEC Switchover : 2500 rpm
* ECU Code : P07
while the blocks might be the same it would be much more cost effective to either buy a D15Z1 or pick up a JDM D15B
D15B Vtec specs:
# 1991-1995 Honda Civic EG4 (Japanese Market)
# 1991-1995 Honda Civic EG8 (Japanese Market)
# 1997 Honda Civic Ferio Vi EK3 (Japanese Market)
OR a D15Z7
* 3-stage VTEC
* Found in:
o 1996-1999 Honda Civic VTi EK3 and Ferio Vi
+ Displacement : 1,493 cc (91.1 cu in)
+ Bore and Stroke : 75 ? 84.5 mm (3.0 ? 3.33 in)
+ Rod Length : 137 mm
+ Rod/Stroke : 1.62
+ Compression : 9.6:1
+ Power : 128 hp (95.4 kW, 130 ps) @ 7000 rpm
+ Torque : 102 ft?lbf (14.2 kg/m, 139 Nm) @ 5300 rpm
+ Valvetrain : SOHC VTEC (3-4 valves per cylinder, depending on rpm)
+ VTEC Switchover : 5800 and 6200 rpm
+ Fuel Control : OBD-2 MPFI
+ ECU Code : P2J
+ Manual Transmission ECU Codes : P2J-003 (OBD2a), P2J-J11 (OBD2b)
+ Lean burn capable
* Bore and Stroke :75,0?84,5 mm
* Rod/Stroke : 1.62
* Compression : 9:3:1
* Power : 128 hp (95.4 kW, 130 ps) @ 8600 rpm
* Torque : 102 ft?lbf (14.1 kg/m, 138 Nm) @ 9200 rpm
* Redline : 7200 rpm
* Rev-limiter : 7500 rpm
* Valvetrain : SOHC VTEC (4 valves per cylinder)
* VTEC Switchover : 1500 rpm
* VTEC crack at : 5500rpm
* Head Code : P08
* Piston Code: P08-010
* Fuel Control : OBD-6 PGM-FI
* ECU : pw0 p08
For a VX motor I'd search www.car-part.com it's a junkyard parts search
For a JDM swap http://www.jdmenginedepot.com or http://www.jspecauto.com/
make sure you get a "full swap" which would include engine tranny and ecu.
JDM engines all have between 35-50k on them.
Dalamar is offline   Reply With Quote
Old 11-15-2010, 06:03 AM   #3
Dalamar's Avatar
edit to the d15b specs
D15B VTEC
o 1991-1995 Honda CRX Del Sol EG1 (America Market)
o 1991-1995 Honda Civic EG4 (Japanese Market)
o 1991-1995 Honda Civic EG8 (Japanese Market)
o 1997 Honda Civic Ferio Vi EK3 (Japanese Market)
+ Bore and Stroke :75,0?84,5 mm
+ Rod/Stroke : 1.62
+ Compression : 9:3:1
+ Power : 128 hp (95.4 kW, 130 ps) @ 8600 rpm
+ Torque : 102 ft?lbf (14.1 kg/m, 138 Nm) @ 9200 rpm
+ Redline : 7200 rpm
+ Rev-limiter : 7500 rpm
+ Valvetrain : SOHC VTEC (4 valves per cylinder)
+ VTEC Switchover : 1500 rpm
+ VTEC crack at : 5500rpm
+ Head Code : P08
+ Piston Code: P08-010
+ Fuel Control : OBD-6 PGM-FI
+ ECU : pw0 p08
Old 12-28-2010, 11:53 PM   #4
get a vx engine before gas goes up to $4.00 gal !
jmaze is offline   Reply With Quote
Never Underestimate the Power of a Great Story shatto General Discussion (Off-Topic) 1 10-31-2009 05:13 PM
Vehicle Finder 101mpg Wanted to Buy 14 05-30-2008 03:26 AM
4 VX wheels for $100 in Chicago area McPatrick For Sale 2 07-17-2007 04:46 PM
New Dodge sub-compact from China. Fuzzy5150 General Fuel Topics 45 07-16-2007 05:39 AM
