civic vx shift not working? - Fuelly Forums
Old 02-25-2013, 06:47 PM   #1
Hello,
Just got a 1995 Honda civic vx. the shift light is not coming on when going throught the gears. I know the light bulb works, when I turn the key on the light does come on. The prev owner did replace the o2 sensor and the distributor. The o2 sensor was replace a year ago. the light was working until he replaced the distributor ( also the check engine light came on) pulled the code. tracked it down to a crank sensor wire that was pushed out of the plug going to the distributor. I reset the ecu by pulling the back up fuse under the hood. shift light still not coming on. Any ideas? Thanks
jcrx is offline   Reply With Quote
Old 02-26-2013, 04:40 PM   #2
Do you have a check engine light on? If so you will not get the shift light.
Rusty94cx is offline   Reply With Quote
Old 04-09-2015, 05:59 PM   #3
sebass's Avatar
Did you get this issue resolved. I just got new dizzy changed as well and my SIL no longer lights up but it use to work just fine before i changed dizzy. Also i did reset ECU with 7.5 fuse pull after service so it's reset. Any ideas. I just hope my lean burn is working. My car is 92 civic vx.
sebass is offline   Reply With Quote
$100 Civic VX 5 wire O2 / LAF sensor. will it work? GasSavers_ian General Maintenance and Repair 3 12-22-2012 08:24 PM
LLR Tires for a 93 Ford Escort GT jj94auto General Fuel Topics 12 05-24-2012 05:43 PM
HELP! Best tire for CRX HF (165/70 vs 155/80 vs 175/70 for economy &/or performance) goobous General Fuel Topics 6 05-23-2012 06:00 AM
