Civic VX O2 Sensor Conumdrum - Fuelly Forums
Old 11-23-2013, 09:54 PM   #1
Okay folks, I'm presently looking for the definitive answer to which type of O2 sensor that I would need to buy to enable lean burn on my Civic Vx. To get right to the point, is there a comparable aftermarket sensor that will give me the same result as the factory OEM O2 sensor? If so, who makes it, what's the part number, where can I find it and whom here from the forum can attest to utilizing one.
I'm certain that this has brought up many times; but the information over the internet is very very conflicting. At present, it would appear that the previous owner had replaced the old O2 sensor with the wrong part number. The car runs fine; but it may explain my lousy gas mileage.
Thank You.
Davo53209 is offline   Reply With Quote
Old 11-23-2013, 10:02 PM   #2
Oh, I just needed to add a few more details. My car is a stock 94 Civic VX Federal, with the D15Z1 engine and 5-wire O2 sensor.
Old 11-24-2013, 07:01 AM   #3
Anyone?
Old 11-24-2013, 07:29 AM   #4
I got the one on amazon for 190$ worked like it should. I'm 99% sure this is the one I bought and from this seller. Amazon.com: NGK 24300 Oxygen Sensor - NGK/NTK Packaging: Automotive
Rusty94cx is offline   Reply With Quote
Old 11-24-2013, 07:53 AM   #5
You can make 100% sure by checking your past orders.
https://www.amazon.com/gp/css/order-history
Old 11-24-2013, 08:41 AM   #6
That's just it, I've never made a past order for my vehicle. However, the underlying question is if whether I'm absolutely committed to purchasing a Honda OEM O2 sensor for my Civic Vx, to enable lean burn to happen.
Old 11-25-2013, 04:55 AM   #7
Sorry, I meant that for Rusty94cx's post right above mine, so he could confirm it for you.
Old 11-25-2013, 11:35 AM   #8
Well from what I've noticed recently, the stamp on the O2 sensor that I have states as LZA09-E1. My understanding is that I would need either A00, or A01. Am I correct on this?
Old 11-26-2013, 12:27 PM   #9
What else can anyone contribute?
Old 11-30-2013, 05:19 PM   #10
A09 on the sensor means its the correct one. Do you have an engine light on? Does it stumble in lean burn? What mileage are you getting?
Slownugly is offline   Reply With Quote
Elio ? GasSavers_BEEF General Fuel Topics 21 06-20-2014 06:08 AM
$100 Civic VX 5 wire O2 / LAF sensor. will it work? GasSavers_ian General Maintenance and Repair 3 12-22-2012 08:24 PM
