civic model years for VX swap - Fuelly Forums
Old 06-07-2007, 07:05 AM   #1
hi,
we are thinking of buying a d15z1 engine and swapping it into a civic hb.
I was wondering if anyone knew which civic model years/trims are compatible with the vx motor?
should I stick to 92-95?
cause I can't help thinking, the newer the chassis...the better condition it might be in.
Any info would be great!
thanks
GasSavers_McGee is offline   Reply With Quote
Old 06-07-2007, 07:22 AM   #2
mrmad's Avatar
92-95 would keep OBD1 (which the VX is) and would make the swap alot simpler then trying to put it in a 96+ Civic.
Old 06-07-2007, 07:28 AM   #3
GasSavers_TomO's Avatar
Agreed, keeping to the 92-95 Civic Chassis would keep the re-wiring to a minimum. It also depends on the state you live in as far as emissions go. Some states only allow a same year or newer engine to be dropped into the chassis.
Edit:
If you don't like the Hatchback rust, but are willing to have a shop/friend or you feel like fixing the rust yourself, PM me, I can show you where to get really cheap repair panels for the hatchback/coupe.
Honda Civic VX Info/Links
Old 06-07-2007, 07:31 AM   #4
Matt Timion's Avatar
92-95 would be easiest due to wiring. I did this swap on an 89, but it takes a lot more work.
Old 06-07-2007, 09:06 AM   #5
thanks for the info, I think I will definately stick to the 92-95 range. Easier is always better
we are going to try to find one without rust, but I'll keep your offer in mind in case we don't succeed.
And the emissions law is a good point, I'll have to look into it.
thanks for the info, I'll let y'all know how it goes!
Old 06-07-2007, 04:53 PM   #6
I asked several mechanics ( and the dealership ) about dropping a VX block in my automatic '93 DX hatch.
I was told it would -not- work because all the wiring would have to be changed out.
They said it would be cheaper to just buy a used VX.
What do you guys know about this ?
Nerds laugh at me is offline   Reply With Quote
Old 06-07-2007, 09:31 PM   #7
Liars! The wiring is not very difficult to do yourself...
I was also told I couldn't go auto to manual, and it was pretty darn easy to do so (except for forgetting parts, ).
Don't let the silly dealerships hold you back.
Poll: Should Stability Control be Standard rh77 General Fuel Topics 14 09-30-2006 09:44 PM
5 different Metros for Sale-Perkasie, Pa / cams XFi For Sale 11 08-26-2006 04:17 AM
taller tranny MetroMPG General Fuel Topics 66 07-09-2006 08:32 PM
The Honda Fit GasSavers_DaX General Fuel Topics 54 05-13-2006 12:52 AM
Extreme hybrids are technically feasible: Sludgy Electric and Solar powered 1 05-10-2006 11:32 AM
