Civic HX engine rebuild for MPG and Durability - Fuelly Forums
Old 11-09-2010, 07:09 PM   #1
Hey everybody,
I am at 215k on my 97 HX. I know the timing belt needs to be done, and I've found myself replacing seals everywhere. The more I think about it, the more I am thinking it may be time to learn how to rebuild and engine.
I'm interested in trying to improve MPG as well as durability. What kinds of changes could I make to a D16Y5 that could improve those?
I'm interested in solid upgrades, but not in spending tons of cash.
If there are upgrades I should consider while I'm in there, what do you think the $$ difference would be between incorporating those updates vs. just building a stock setup ?
Thanks for your suggestions and insight.
longdrive352 is offline   Reply With Quote
Old 11-10-2010, 08:54 AM   #2
slogfilet's Avatar
Re: Civic HX engine rebuild for MPG and Durability
You may also want to look at low-mileage engines imported from Japan. Due to costs and emissions laws over there, there is a good supply of engines with around 40-60k miles on them. They can usually be had pretty cheaply (especially VTEC-E engines, it seems.) Maybe someone here can pipe up with a reputable importer?
slogfilet is offline   Reply With Quote
Old 11-13-2010, 07:45 AM   #3
kamesama980's Avatar
Whether you're doing stock or upgraded setups:
1. make sure everythings clean enough to eat out of when you put it back together.
2. quadruple check every measurement.
3. torque everything exactly.
3a. chase all the threads with a tap or die. make sure they don't have oil, anti-sieze, lock-tite, or anything else on them unless the factory manual says so. torque=frction x tension. friction down = tension up at the same torque and thta's how you strip threads and break bolts.
3b. Don't go an extra 5 ftlb to be sure, a friend of mine tore up his rod bearings because he put an extra couple ftlb on the rod bolts. it was just enough they didn't stretch right and ate 2 with visible wear on the other 4 after 400 miles.
as for upgrading stuff: the easiest thing to do for no extra charge is when you get the head and/or block milled to get a nice straight surface for the head gasket, have them take off a little extra to bump the compression. compression=power+mpg.
-Russell
