Chose a header!!!! help - Fuelly Forums
Old 03-30-2009, 08:19 AM   #1
Hi, well i have a Civic ef HB EX with a 1.3 EFi engine swap D13B and i want to change the header so i need some recommendation cause its have the stock header that sound really weird and i was thinking to use a d15b stock header but i saw that my down pipe its really small and i don't want to mess my lil engine power with another header you think i can use the d15b header without any mpg loss or power loss???? my header its the one that come with big catalyst close to the 4 exhaust.
thankss any help..
kakaroto_ss4 is offline   Reply With Quote
Old 03-31-2009, 04:04 PM   #2
|V3|2D
thisisntjared's Avatar
in your case i dont know what is available... with such small displacement out of the d series i wouldnt trust anything to help with mpg.... the only thing that might help highway mpg is a turbo, but then when you step on it you will lose mpg...
Old 03-31-2009, 04:09 PM   #3
How would adding a turbo to an existing engine help FE? The only way I know of a turbo helping FE is by allowing you to choose a smaller engine. The energy that spools a turbo is not free, it comes from the exhaust stroke...
Old 03-31-2009, 04:49 PM   #4
A Civic ef HB EX
What? ef HB EX? Year?
I would recomind a light weight header swap, but every after market header is going to be wider diameter than the rest of the exhaust system.
I can see the dilema.
They make those stock headers out of iron, my stainless steel one is a fraction of the weight.
Any turbo system has its special type of header to go with it, as for as position and type of mounting. If your looking to buy a header, you could go big and go turbo.
I've heard turbo does great for freeway cruising, but crap MPG in town.
Every time you shift, you burn gas to charge that turbo.
No personal experience only hear say.
Turbo use anyone?
William0882 is offline   Reply With Quote
Old 04-01-2009, 05:05 PM   #5
|V3|2D
thats not exactly how it works...
when the turbo gains a certain momentum under cruising conditions it can allow for negative pressure to occur between pulses of the engine depending on how free flowing the exhaust is after the turbo. its a strange phenomenon that some have experienced in civics that have had a good tune. i would never add a turbo for mpg though it is just a minor added benefit. there could be more too it as far as efficiences in air flow, but i am not certain on the details before combustion.
Old 04-13-2009, 06:28 AM   #6
A Civic ef HB EX
Turbo use anyone?
1990. ok soo i'll just go for the header thanks.
Old 04-13-2009, 07:32 PM   #7
|V3|2D
... for mpg? or for full throttle power?
Old 04-16-2009, 04:07 PM   #8
Crap my header is illegal.
The guy at the smog place tells me I fail visual inspection of my car, Im like
"I know its dirty, but aren't you only looking at the tail pipe?"
Apparently because there isn't a specific number stamped into it, so their illegal.
My hyperlite crx apparently failed smog by burracracy.
(bangs head on steering wheel)
Old 04-16-2009, 04:34 PM   #9
Do you live in California? If so, those kind of parts need to be CARB approved.
http://www.flyinmiata.com/tech/carb.php
Can't delete fill ups posted by a friend. missmaispace Fuelly Web Support and Community News 4 08-18-2014 09:18 PM
A Theory...[Hybrid?] GasSavers_silvergt Experiments, Modifications and DIY 4 07-02-2008 06:23 PM
Hey, from Houston!! johnsoci Introduce Yourself - New member Welcome 0 07-01-2008 03:30 PM
Cam regrinds for Atkinson cycle? omgwtfbyobbq General Fuel Topics 14 07-11-2007 06:03 AM
Honda 2005 1.8L i-VTEC 88HF General Fuel Topics 4 07-09-2007 05:40 PM
