03-30-2009, 08:19 AM
Chose a header!!!! help
Hi, well i have a Civic ef HB EX with a 1.3 EFi engine swap D13B and i want to change the header so i need some recommendation cause its have the stock header that sound really weird and i was thinking to use a d15b stock header but i saw that my down pipe its really small and i don't want to mess my lil engine power with another header you think i can use the d15b header without any mpg loss or power loss???? my header its the one that come with big catalyst close to the 4 exhaust.
thankss any help..
03-31-2009, 04:04 PM
|V3|2D
in your case i dont know what is available... with such small displacement out of the d series i wouldnt trust anything to help with mpg.... the only thing that might help highway mpg is a turbo, but then when you step on it you will lose mpg...
03-31-2009, 04:09 PM
How would adding a turbo to an existing engine help FE? The only way I know of a turbo helping FE is by allowing you to choose a smaller engine. The energy that spools a turbo is not free, it comes from the exhaust stroke...
04-01-2009, 05:05 PM
|V3|2D
Originally Posted by William0882
Every time you shift, you burn gas to charge that turbo.
thats not exactly how it works...
when the turbo gains a certain momentum under cruising conditions it can allow for negative pressure to occur between pulses of the engine depending on how free flowing the exhaust is after the turbo. its a strange phenomenon that some have experienced in civics that have had a good tune. i would never add a turbo for mpg though it is just a minor added benefit. there could be more too it as far as efficiences in air flow, but i am not certain on the details before combustion.
03-31-2009, 04:49 PM
A Civic ef HB EX
What? ef HB EX? Year?
I would recomind a light weight header swap, but every after market header is going to be wider diameter than the rest of the exhaust system.
I can see the dilema.
They make those stock headers out of iron, my stainless steel one is a fraction of the weight.
Any turbo system has its special type of header to go with it, as for as position and type of mounting. If your looking to buy a header, you could go big and go turbo.
I've heard turbo does great for freeway cruising, but crap MPG in town.
No personal experience only hear say.
Turbo use anyone?
04-13-2009, 06:28 AM
A Civic ef HB EX
Turbo use anyone?
1990. ok soo i'll just go for the header thanks.
04-13-2009, 07:32 PM
|V3|2D
... for mpg? or for full throttle power?
04-16-2009, 04:07 PM
Crap my header is illegal.
The guy at the smog place tells me I fail visual inspection of my car, Im like
"I know its dirty, but aren't you only looking at the tail pipe?"
Apparently because there isn't a specific number stamped into it, so their illegal.
My hyperlite crx apparently failed smog by burracracy.
(bangs head on steering wheel)
04-16-2009, 04:34 PM
Do you live in California? If so, those kind of parts need to be CARB approved.
http://www.flyinmiata.com/tech/carb.php
