Originally Posted by krousdb
One other note about the LAF sensor wiring is that you will find 7 wires on the engine side wiring harness and 7 termninals in the LAF connector, but only 5 wires from the connector to the LAF sensor. Two of the terminals are connected to a calibrating resistor that is located in the LAF terminal. This resistor is typically 4.3K ohms.
Is this on the engine harness side or the oxygen sensor side? I'm going to be using a 8-wire plug from a obd1 distributor and not the actual oxygen sensor plug. Images are as follows:
Here is the plug I'm using (sorry so blurry)
And a picture I made to help with the discussion:
